Netdata Community
Add notification handler for betteruptime.com
Hi guys,
Would it be possible to add a notification provider / handler for betteruptime.com? They’re growing fast in the DevOps community and have some big customers like IBM, already.
Their API is excellent too. This is the incidents API: Incidents API - Better Uptime
And they offer heartbeat monitors too, which could be cool to integrate as well: Heartbeats API - Better Uptime
Cheers
Hi @binaryfire
I see Incidents API supports:
  • Creating a new incident
  • Deleting an existing incident
So how it supposed to work? We need to create incidents when an alarm state is WARN/CRIT and delete it when CLEARED?
Yes, that’s what I was thinking. But just for WARN, not CRIT.
However I just realised I can do what I need with a custom notification (webhook) so perhaps a direct integration isn’t necessary?
@binaryfire it would be awesome if you tried to implement it yourself and make a contribution. A webhook is a good start actually.
Just create a topic on #agent-development in case you want to discuss further while you implement it. We are here to help you to become a Netdata contributor!
