Could be great if dashboards metadata (as text/json/markdown) were exportable and importable. That way they can be moved between spaces, used to clone dashboards or designed/redesigned offline.
Environments with many servers / systems / devices will require many dashboards with key stats, it is not practical to create a large number of dashboards or add charts/text to them now. It’s simple to do… but not at scale.
If we could access the dashboard layout in a format that is editable, then we can create what we need offline and import it. Or create one as a template, then modify for 100s of servers etc, then re-import.
The dashboard import process should support multiple dashboards in one document or allow multiple documents to be import at the same time.
