Netdata Community
General war room: be able to rename or delete
Greets! Thanks for the awesome netdata cloud.
Present behaviour
The General war room is assumed to be the default war room, cannot be renamed, nor deleted.
Proposed behaviour
No assumptions / special treatment.
  • Start with 0 war rooms, and you are prompted to created one via web UI or you create via API
  • all war rooms can be renamed / deleted
Or, you can rename the default one (if for technical reasons internally its too complicated to delete in implementation)
For non enterprise collaborative teams the present default behavior can work, but for enterprises adopting netdata a certain degree of flexibility is expected.
Thanks!
