Netdata Community
Show resolution of charts
The local versions shows the resolution of the chart when the mouse is moved over the time on the lower right corner. E.g. in latest 6 h chart it shows “resolution 32 secs, collected every 1 sec”. This tells that the values are averaged in 32 second intervals, filtering possible peaks, visible with better resolution.
This information is missing from cloud graphs (or I did not find it). It shows only the collected information.
It would be easy to add it in current tool tip, right?
Hi @timoke ,
Thanks for raising this and sharing your feedback.
We have plans to include this on a next iterations on charts, so it will be part of the tooltip when we have aggregated datapoints.
