systemd_scope_units_state
Linux | Systemd units
Systemd is a suite of basic building blocks for a Linux system. It provides a system and service manager that runs as PID 1 and starts the rest of the system.
The Netdata Agent monitors the systemd scope units state. The systemd_scope_units_state alert indicates that one or more of the systemd-scope units are in the failed state. A systemd scope unit “failed” when the service process returned error code on exit, or crashed, an operation timed out, or after too many restarts. The cause of a failed states is stored in a log.
Read more about systemd
Here is some useful information about systemd from
wikipedia 1
Systemd includes features like on-demand starting of daemons, snapshot support, process tracking, and Inhibitor Locks. Systemd is not just the name of the init daemon, but also refers to the entire software bundle around it, which, in addition to the systemd init daemon, includes the daemons journald, logind and networkd, and many other low-level components. In January 2013, Poettering described systemd not as one program, but rather a large software suite that includes 69 individual binaries. As an integrated software suite, systemd replaces the startup sequences and runlevels controlled by the traditional init daemon, along with the shell scripts executed under its control. Systemd also integrates many other services that are common on Linux systems by handling user logins, the system console, device hotplugging, scheduled execution (replacing cron), logging, hostnames and locales.
Like the init daemon, Systemd is a daemon that manages other daemons, which, including systemd itself, are background processes. systemd is the first daemon to start during booting and the last daemon to terminate during shutdown. The systemd daemon serves as the root of the user space’s process tree. The first process (PID 1) has a special role on Unix systems, as it replaces the parent of a process when the original parent terminates. Therefore, the first process is particularly well suited for the purpose of monitoring daemons.
systemd’s core components include the following:
  • systemctl is a command to introspect and control the state of the systemd system and service
    manager. Not to be confused with sysctl.
See more on systemd-scope The following text originates from the systemd.scope man page.[2](https://www.freedesktop.org/software/systemd/man/systemd.scope.html)
Scope units are not configured via unit configuration files, but are only created programmatically using the bus interfaces of systemd. They are named similar to filenames. A unit whose name ends in .scope refers to a scope unit. Scopes units manage a set of system processes. Unlike service units, scope units manage externally created processes, and do not fork off processes on its own.
The main purpose of scope units is grouping worker processes of a system service for organization and for managing resources.
Unlike service units, scope units have no “main” process: all processes in the scope are equivalent. The lifecycle of the scope unit is thus not bound to the lifetime of one specific process, but to the existence of at least one process in the scope. This also means that the exit statuses of these processes are not relevant for the scope unit failure state. Scope units may still enter a failure state, for example due to resource exhaustion or stop timeouts being reached, but not due to programs inside of them terminating uncleanly. Since processes managed as scope units generally remain children of the original process that forked them off, it is also the job of that process to collect their exit statuses and act on them as needed.
References and source
  1. systemd on Wikipedia
  2. Man page for systemd.scope
Troubleshooting section:
General approach
When a scope is in a failed state, you should always try to gather more information about it.
  1. Identify which scope units fail. Open the Netdata dashboard, find the current active alarms under the active alarms tab and look into its chart. (systemdunits_scope_units.scope_unit_state). In this chart, identify which slice units are in state with value 5
  2. Gather more information about the failing scope unit
    root@netdata~ # systemctl status <scope_name>.scope
  3. Check the log messages from the command of step 2.
