systemd_socket_units_state
Linux | Systemd units
Systemd is a suite of basic building blocks for a Linux system. It provides a system and service
manager that runs as PID 1 and starts the rest of the system.
The Netdata Agent monitors the systemd socket units state. Receiving this alerts indicates that one or more of the systemd socket units are in the failed state. In most of the cases this is correlated with the service, which manages the socket. A systemd socket unit “failed” when the service process returned error code on exit, or crashed, an operation timed out, or after too many restarts. The cause of a failed states is stored in a log.
Read more about systemd
Here is some useful information about systemd from
wikipedia 1
Systemd includes features like on-demand starting of daemons, snapshot support, process tracking, and Inhibitor Locks. Systemd is not just the name of the init daemon, but also refers to the entire software bundle around it, which, in addition to the systemd init daemon, includes the daemons journald, logind and networkd, and many other low-level components. In January 2013, Poettering described systemd not as one program, but rather a large software suite that includes 69 individual binaries. As an integrated software suite, systemd replaces the startup sequences and runlevels controlled by the traditional init daemon, along with the shell scripts executed under its control. systemd also integrates many other services that are common on Linux systems by handling user logins, the system console, device hotplugging, scheduled execution (replacing cron), logging, hostnames and locales.
Like the init daemon, systemd is a daemon that manages other daemons, which, including systemd itself, are background processes. systemd is the first daemon to start during booting and the last daemon to terminate during shutdown. The systemd daemon serves as the root of the user space’s process tree. The first process (PID1) has a special role on Unix systems, as it replaces the parent of a process when the original parent terminates. Therefore, the first process is particularly well suited for the purpose of monitoring daemons.
  • systemctl is a command to introspect and control the state of the systemd system and service manager. Not to be confused with sysctl.
See more on systemd.socket units
A unit configuration file whose name ends in .socket encodes information about an IPC or network socket or a file system FIFO controlled and supervised by systemd, for socket-based activation. For each socket unit, a matching service unit must exist, describing the service to start on incoming traffic on the socket. The name of the .service unit is by default the same as the name of the .socket unit.
Note that the daemon software configured for socket activation with socket units needs to be able to accept sockets from systemd, either via systemd’s native socket passing interface (see sd_listen_fds(3) for details about the precise protocol used and the order in which the file descriptors are passed) or via traditional inetd(8)-style socket passing (i.e. sockets passed in via standard input and output, using StandardInput=socket in the service file).
All network sockets allocated through .socket units are allocated in the host’s network namespace
(see network_namespaces(7)). This does not mean however that the service activated by a configured socket unit has to be part of the host’s network namespace as well. It is supported and even good practice to run services in their own network namespace (for example through PrivateNetwork=, see systemd.exec(5)), receiving only the sockets configured through socket-activation from the host’s namespace. In such a set-up communication within the host’s network namespace is only permitted through the activation sockets passed in while all sockets allocated from the service code itself will be associated with the service’s own namespace, and thus possibly subject to a a much more restrictive configuration. 2
References and source
  1. systemd on wikipedia
  2. systemd.socket on debian.org
Troubleshooting section:
General approach
When a socket is in failed state, you should always try to gather more information about it.
  1. Identify which socket units fail. Open the Netdata dashboard, find the current active alarms under
    the active alarms tab and look into its chart. systemdunits_service_units.socket_unit_state chart. Check which sockets are in state with value 5.
  2. Gather more information about the failing socket and the service that manages it (in most of the cases they will have the same name). We advise you to run the following commands in two different terminals.
    root@netdata~ # journalctl -u <service_name>.service -f
    root@netdata~ # journalctl -u <socket_name>.socket -f
    These commands will monitor the journalctl log messages for your socket/service unit.
  3. In a new terminal, try to restart the service.
    root@netdata~ # systemctl restart <service_name>.service
  4. Check the log messages from the command of step 2.
Run the service of the socket in debug mode
  2. Stop the service that manages this socket (in most of the cases the service will have the same name with the socket)
    root@netdata~ # systemctl stop <service_name>.service
  3. Try to start it with the SYSTEMD_LOG_LEVEL=debug env variable. Let’s assume in our case we want to debug the systemd-networkd service
    root@netdata~ # SYSTEMD_LOG_LEVEL=debug /lib/systemd/systemd-networkd
    This command will start your service in debug mode.
  4. Check the log messages.
