We are encountering a monitoring error that interrupts the dashboard monitoring for a host(see screenshot below for reference).
As per checking the error logs, I am getting plugin errors that Im not familiar with. Can someone help me address this issue? Thanks.
I would start by looking at the charts in the “Applications” menu. You will almost certainly find there a process group that consumes too many of your machine’s resources around the times when we see these interruptions. If you see the culprit being other
, you will need to see which processes are normally running on your machine and configure apps_groups.conf, to ensure they are properly named.
