Hi all, right now I have a typical alarm that notifies me when a threshold has been reached. Unfortunately it’s not very useful given how much the data fluctuates. I’d like to modify the alarm so that I evaluate the zscore.
Question:
What functions are available to the calc parameter? Looking at the docs it just mentions a range of expressions - but nothing like avg() or stddev() (for example).
I do see the zscore plugin - but I was hoping to do this within the alarm.
2021-12-02 12:26:27: netdata ERROR : MAIN : Health configuration at line 9 of file '/etc/netdata/conf.d/health.d/test.conf' for alarm 'system_active_processes' at key 'calc' has unparse-able expression '($this - mean) / stddev': remaining characters after expression at 'mean) / stddev'
Are these the only expressions available for calc?
Hi @mjtice i’ve had a play around and asked internally and below is an example of how to make a zscore based alarm.
alarm: cpu_user_mean
on: system.cpu
lookup: mean -60s of user
every: 10s
alarm: cpu_user_stddev
on: system.cpu
lookup: stddev -60s of user
every: 10s
alarm: cpu_user_zscore
on: system.cpu
lookup: mean -10s of user
calc: ($this - $cpu_user_mean) / $cpu_user_stddev
every: 10s
warn: $this < -2 or $this > 2
crit: $this < -3 or $this > 3
Here you can see i make an alarm for mean and sttdev and then reference them in my zscore alarm. I then make a warning if abs(zscore) > 2 or critical if abs(zscore) > 3.
I think you could play around with this approach to get it working for your use case.
I think would be best if we had just a zscore function you could use so i’ll make a feature request for this.
