Hi guys good afternoon, i’m recieving this messages since 10 days ago,i want to know if its something to worry about or i can ignore it.
10min disk utilization = 92%
the percentage of time the disk was busy, during the last 10 minutesALARM
sdaFAMILY
WARNINGSEVERITY
Sun Nov 6 02:46:25 MST 2022TIME
$this > $green * (($status >= $WARNING) ? (0.7) : (1))EVALUATED EXPRESSION
[ $this = 92.0061515 ] [ ${green} = 90 ] [ $status = 1 ] [ $WARNING = 3 ]EXPRESSION VARIABLES
The host has 3 WARNING and 1 CRITICAL alarm(s) raised.
Thanks in advance
The alarm is calculated based on the data from disk_util.sda. Please read the description of the chart
Disk Utilization measures the amount of time the disk was busy with something. This is not related to its performance. 100% means that the system always had an outstanding operation on the disk. Keep in mind that depending on the underlying technology of the disk, 100% here may or may not be an indication of congestion.
You can most likely ignore it unless you are using a disk with a legacy controller.
