10s_ipv4_tcp_resets_received
OS: Linux, FreeBSD
TCP reset is an abrupt closure of the session. It causes the resources allocated to the connection to be immediately released and all other information about the connection to be erased.
The Netdata Agent monitors the average number of received TCP RESETS over the last 10 seconds. This can indicate that the system is trying to establish a connection to a server port on which no process is listening. This can also indicate a SYN reset attack.
See more about TCP Resets
TCP uses a three-way handshake to establish a reliable connection. The connection is full duplex, and both sides synchronize (SYN) and acknowledge (ACK) each other. The exchange of these four flags is performed in three steps: SYN, SYN-ACK, and ACK
When an unexpected TCP packet arrives at a host, that host usually responds by sending a reset packet back on the same connection. A reset packet is one with no payload and with the RST bit set in the TCP header flags. There are a few circumstances in which a TCP packet might not be expected. The most common cases are:
A TCP packet received in a non-existed TCP PORT
An aborting connection
Half opened connections
Time wait assassination
Listening endpoint Queue is Full
A TCP Buffer Overflow
Basically, A TCP Reset usually occurs when a system receives data which doesn’t agree with its view
of the connection.
References and source:
Troubleshooting section:
General approach
Try using Wireshark to inspect the network packets.
Wireshark is a free and open-source packet analyzer. It is used for network troubleshooting,
analysis, software and communications protocol development.
Since you might won’t be able to probe your traffic with wireshark in your host machine, You can
export it in a dump file and analyze it in a second iteration.
Try to export the traffic in your host with
tcpdump.root@netdata # tcpdump -i any 'tcp[tcpflags] & (tcp-rst) == (tcp-rst)' -s 65535 -w output.pcapYou must stop the capture after a certain observation period (60s up to 5 minutes). This command will create a dump file which can be interpreted by Wireshark that contains all the TCP packets with RST flag set.
Copy this file in your workstation and examine it with Wireshark.
Counter measure on malicious TCP resets
SYN cookie is a technique used to resist IP address spoofing attacks. In particular, the use of SYN cookies allows a server to avoid dropping connections when the SYN queue fills up.
Enable SYN cookies in Linux
Check if your system has the SYN cookies service enabled
root@netdata # cat /proc/sys/net/ipv4/tcp_syncookiesIf the value is 1, then the service is enabled, if not proceed to step 2.
Bump this
net.ipv4.tcp_syncookies=1value under/etc/sysctl.conf -
Apply the configuration
root@netdata # sysctl -p to apply the configuration.
Enable SYN cookies in FreeBSD
root@netdata # sysctl net.inet.tcp.syncookies_onlyIf the value is 1, then the service is enabled, if not proceed to step 2.
Bump this
net.inet.tcp.syncookies_only=1value under/etc/sysctl.conf -
root@netdata~ # /etc/rc.d/sysctl reload
The use of SYN cookies does not break any protocol specifications, and therefore should be compatible with all TCP implementations. There are, however, a few caveats that take effect when SYN cookies are in use.
