adaptec_raid_pd_state
OS: Any
A RAID controller is a card or chip located between the operating system and a storage drive (usually a hard drive). This is an alert about the Adaptec raid controller. The Netdata Agent checks the physical device statuses which are managed by your raid controller.
This alert is triggered in critical state when the physical device is offline. Below you can find how tolerant each RAID configuration is in cases of disk failures.
Fault tolerance for the most popular raid configurations
RAID 0 provides no fault tolerance. Any drive failures will cause data loss, so do not use this
on a mission critical server. -
RAID 1 configuration is best used for situations where capacity isn’t a requirement but data
protection is. This set up mirrors two disks so you can have 1 drive fail and still be able to
recover your data. -
RAID 5 can withstand a single drive failure with a tradeoff in performance.
RAID 6 can withstand two disk failures at one time.
RAID 10 can survive a single drive failure per array.
Your system manages your Adaptec raid controller via the ARCCONF command line tool. You can find more information about this utility in the user’s guide for the ARCCONF.
Troubleshooting section
Verify a bad disk
Check the smart report for the drives in your RAID controller:
root@netdata # arcconf GETSMARTSTATS 1
If a disk is degraded, you should consider replacing it. Your Adaptec RAID card will automatically start to rebuild a faulty hard drive when you replace it with a healthy one.
