I want to add a Node but this comes
curl: (6) Could not resolve host: my-netdata.io
connecting to netdata?
I’m having the same issue. Can’t seem to resolve the hostname “my-netdata.io”.
Hello guys! Thanks for reporting this, we are looking into it, will keep you updated.
For some reason your DNS has not propagated our from your name servers.
I did dig @BARBARA.NS.CLOUDFLARE.COM my-netdata.io - resolved fine (and its your specified name server)
I did dig @8.8.8.8 my-netdata.io. - nada, bupkis. That is googles DNS IP
Hope that helps.
The issue is fixed. Thanks for reporting and help @fb_sean @cackerman @jhesketh
For me it didnt fixxed same issue
2 of 3 servers can start this but one says curl: (6) Could not resolve host: http://my-netdata.io/
Now fixxed it works now
FYI it was an issue with some DNSSEC changes we made, that weren’t applied correctly.
I have the same problem. I can not resolve my-netdata.io.
Already tried different DNS servers.
HI, @smay , Thanks for reporting your issue.
Can you please provide the name servers you are using to test it?
If your host using some dns cache , please clear it.
Thanks.
Currently experiencing this issue.
