load_average_1
OS: Linux
This alert calculates the system load average (CPU and I/O demand) over the period of one minute.
If you receive this alert, it means that your system is overloaded.
What does "load average" mean
The term system load average on a Linux machine, measures the number of threads that are currently working and those waiting to work (CPU, disk, uninterruptible locks). 1 2
So simply stated: it measures the number of threads that aren’t idle.
What does "overloaded" mean
The term overloaded can be better illustrated using an example as Andre Lewis says in Understanding Linux CPU Load - when should you be worried? 3 .
We are going to take a single core CPU system and think of its core count as bridge lanes.
On a 0.5 load average, the traffic on the bridge is fine, it is at 50% of its capacity.
If the load average is at 1, then the bridge is full, and it is utilized 100%.
If the load average gets to 2 (remember we are on a single core machine), it means that there is one lane that is passing the bridge and one other full lane that waits on the side. On this example, traffic and thus cars, are processes.
So this is how you can imagine CPU load, but keep in mind that load average counts also I/O demand, so there is an analogous example there.
How we calculate the alert
On Netdata, in the load.conf file, under the health.d directory, you can see how we calculate when the alert should be raised.
First, there is
load_cpu_numberwhere it provides theload_averagealerts with the core count of the machine. -
In the line
warn: ($this * 100 / $load_cpu_number) > (($status >= $WARNING) ? 700 : 800),
($this * 100 / $load_cpu_number)is the current system load average in %. -
Last, we check if that value exceeds 700% or 800% (depending on the
$statusof the alert).
References and Sources
Troubleshooting Section
Determine if the problem is CPU or I/O bound
First you need to check if you are running on a CPU load or an I/O load problem.
- You can use
vmstat(orvmstat 1, to set a delay between updates in seconds)
root@netdata~ # vmstat
procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
r b swpd free buff cache si so bi bo in cs us sy id wa st
8 0 1200384 168456 48840 1461540 4 14 65 51 334 196 3 1 95 0 0
The procs column, shows;
r: The number of runnable processes (running or waiting for run time).
b: The number of processes blocked waiting for I/O to complete.
After that, you can use the ps and specifically ps -eo s,user,cmd | grep ^[RD].
- The
grepcommand will fetch the processes that their state code starts either with R (running or runnable (on run queue)) or D(uninterruptible sleep (usually IO)).
Note: It would be helpful to close any of the main consumer processes, but Netdata strongly suggests knowing exactly what processes you are closing and being certain that they are not necessary.
Check per-process CPU/disk usage to find the top consumers
Use
top:root@netdata~ # top -o +%CPU -iHere, you can see which processes are the main cpu consumers on the
%CPUcolumn. -
Use
iotop:
iotopis a useful tool, similar totop, used to monitor Disk I/O usage, if you don’t have it, then install itroot@netdata~ # sudo iotopUsing this, you can see which processes are the main Disk I/O consumers on the
IOcolumn.
