megacli_bbu_cycle_count
OS: Any
This is an alert about the battery backup unit in the MegaCLI controller. The Netdata Agent monitors
the average battery backup unit charge cycles count over the last 10 seconds. This alert indicates
that a high number of full recharge cycles have been elapsed in the unit’s lifetime. This metrics
may affect the battery relative capacity.
This alert is triggered in warning state when the number of charge cycles is greater than 100 and in
critical state when it is greater than 500.
References and source
Troubleshooting section:
General approach
Gather more information about your battery units in all of your adapters
root@netdata # megacli -AdpBbuCmd -GetBbuStatus -aALL -
Perform a battery check in the battery which had low relative charge. Before perform any
action, consult the manual’s 1 section {7.14}root@netdata # megacli -AdpBbuCmd -BbuLearn -aX // X is the adaptor's number -
Replace the battery in question if needed.
