Monitoring postgres does not show anything
Hi, am having trouble to get the postgres plugin toproduce Charts
Environment
Debian Buster.
netdata Version v1.32.1-71-g4a50934c1
It seems that the plugin works correct. See here:
netdata$ /opt/netdata/usr/libexec/netdata/plugins.d/python.d.plugin 1 debug trace postgres
022-01-17 11:22:24: python.d INFO: plugin[main] : using python v2
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : looking for '/opt/netdata/etc/netdata/python.d.conf'
2022-01-17 11:22:24: python.d INFO: plugin[main] : '/opt/netdata/etc/netdata/python.d.conf' was not found
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : looking for '/opt/netdata/usr/lib/netdata/conf.d/python.d.conf'
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : '/opt/netdata/usr/lib/netdata/conf.d/python.d.conf' is loaded
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : looking for 'pythond-jobs-statuses.json' in /opt/netdata/var/lib/netdata
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : loading '/opt/netdata/var/lib/netdata/pythond-jobs-statuses.json'
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : '/opt/netdata/var/lib/netdata/pythond-jobs-statuses.json' is loaded
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : [postgres] looking for 'postgres.conf' in ['/opt/netdata/etc/netdata/python.d', '/opt/netdata/usr/lib/netdata/conf.d/python.d']
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : [postgres] loading '/opt/netdata/etc/netdata/python.d/postgres.conf'
2022-01-17 11:22:24: python.d DEBUG: plugin[main] : [postgres] '/opt/netdata/etc/netdata/python.d/postgres.conf' is loaded
2022-01-17 11:22:24: python.d INFO: plugin[main] : [postgres] built 4 job(s) configs
2022-01-17 11:22:24: python.d DEBUG: postgres[socket] : server version: 90615
2022-01-17 11:22:24: python.d DEBUG: postgres[socket] : superuser: False
2022-01-17 11:22:24: python.d DEBUG: postgres[socket] : discovered databases ['Confluence', 'postgres']
2022-01-17 11:22:24: python.d DEBUG: postgres[socket] : discovered secondaries: []
2022-01-17 11:22:24: python.d INFO: plugin[main] : postgres[socket] : check success
CHART netdata.runtime_postgres_local '' 'Execution time for postgres_local' 'ms' 'python.d' netdata.pythond_runtime line 145000 1 '' 'python.d.plugin' 'postgres'
2022-01-17 11:22:24: python.d DEBUG: postgres[socket] : started, update frequency: 1
2022-01-17 11:22:24: python.d INFO: plugin[main] : postgres[tcp] : already served by another job, skipping it
2022-01-17 11:22:24: python.d INFO: plugin[main] : postgres[tcpipv4] : already served by another job, skipping it
2022-01-17 11:22:24: python.d INFO: plugin[main] : postgres[tcpipv6] : already served by another job, skipping it
CHART postgres_local.Confluence_db_stat_tuple_returned '' 'Tuples returned from db: Confluence' 'tuples/s' 'db Confluence' 'postgres.db_stat_tuple_returned' line 60004 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_tup_returned' 'sequential' incremental 1 1 ' '
DIMENSION 'Confluence_tup_fetched' 'bitmap' incremental 1 1 ' '
BEGIN postgres_local.Confluence_db_stat_tuple_returned 0
SET 'Confluence_tup_returned' = 160153894601
SET 'Confluence_tup_fetched' = 82415304805
END
CHART postgres_local.Confluence_db_stat_tuple_write '' 'Tuples written to db: Confluence' 'writes/s' 'db Confluence' 'postgres.db_stat_tuple_write' line 60003 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_tup_inserted' 'inserted' incremental 1 1 ' '
DIMENSION 'Confluence_tup_updated' 'updated' incremental 1 1 ' '
DIMENSION 'Confluence_tup_deleted' 'deleted' incremental 1 1 ' '
DIMENSION 'Confluence_conflicts' 'conflicts' incremental 1 1 ' '
BEGIN postgres_local.Confluence_db_stat_tuple_write 0
SET 'Confluence_tup_inserted' = 30152082
SET 'Confluence_tup_updated' = 2321650
SET 'Confluence_tup_deleted' = 25995643
SET 'Confluence_conflicts' = 0
END
CHART postgres_local.backend_usage '' '% of Connections in use' 'percentage' 'backend processes' 'postgres.backend_usage' stacked 60026 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'available' 'available' percentage-of-absolute-row 1 1 ' '
DIMENSION 'used' 'used' percentage-of-absolute-row 1 1 ' '
BEGIN postgres_local.backend_usage 0
SET 'available' = 76
SET 'used' = 21
END
CHART postgres_local.postgres_db_stat_connections '' 'Current connections to db: postgres' 'count' 'db postgres' 'postgres.db_stat_connections' line 60009 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_connections' 'connections' absolute 1 1 ' '
BEGIN postgres_local.postgres_db_stat_connections 0
SET 'postgres_connections' = 1
END
CHART postgres_local.postgres_db_stat_temp_files '' 'Temp files written to disk: postgres' 'files' 'db postgres' 'postgres.db_stat_temp_files' line 60015 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_temp_files' 'files' incremental 1 1 ' '
BEGIN postgres_local.postgres_db_stat_temp_files 0
SET 'postgres_temp_files' = 0
END
CHART postgres_local.Confluence_db_stat_connections '' 'Current connections to db: Confluence' 'count' 'db Confluence' 'postgres.db_stat_connections' line 60001 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_connections' 'connections' absolute 1 1 ' '
BEGIN postgres_local.Confluence_db_stat_connections 0
SET 'Confluence_connections' = 20
END
CHART postgres_local.postgres_db_stat_temp_bytes '' 'Temp files written to disk: postgres' 'KiB/s' 'db postgres' 'postgres.db_stat_temp_bytes' line 60014 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_temp_bytes' 'size' incremental 1 1024 ' '
BEGIN postgres_local.postgres_db_stat_temp_bytes 0
SET 'postgres_temp_bytes' = 0
END
CHART postgres_local.postgres_db_stat_tuple_write '' 'Tuples written to db: postgres' 'writes/s' 'db postgres' 'postgres.db_stat_tuple_write' line 60011 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_tup_inserted' 'inserted' incremental 1 1 ' '
DIMENSION 'postgres_tup_updated' 'updated' incremental 1 1 ' '
DIMENSION 'postgres_tup_deleted' 'deleted' incremental 1 1 ' '
DIMENSION 'postgres_conflicts' 'conflicts' incremental 1 1 ' '
BEGIN postgres_local.postgres_db_stat_tuple_write 0
SET 'postgres_tup_inserted' = 0
SET 'postgres_tup_updated' = 0
SET 'postgres_tup_deleted' = 0
SET 'postgres_conflicts' = 0
END
CHART postgres_local.Confluence_locks '' 'Locks on db: Confluence' 'locks' 'db Confluence' 'postgres.db_locks' line 60048 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_ExclusiveLock' 'ExclusiveLock' absolute 1 1 ' '
DIMENSION 'Confluence_RowShareLock' 'RowShareLock' absolute 1 1 ' '
DIMENSION 'Confluence_SIReadLock' 'SIReadLock' absolute 1 1 ' '
DIMENSION 'Confluence_ShareUpdateExclusiveLock' 'ShareUpdateExclusiveLock' absolute 1 1 ' '
DIMENSION 'Confluence_AccessExclusiveLock' 'AccessExclusiveLock' absolute 1 1 ' '
DIMENSION 'Confluence_AccessShareLock' 'AccessShareLock' absolute 1 1 ' '
DIMENSION 'Confluence_ShareRowExclusiveLock' 'ShareRowExclusiveLock' absolute 1 1 ' '
DIMENSION 'Confluence_ShareLock' 'ShareLock' absolute 1 1 ' '
DIMENSION 'Confluence_RowExclusiveLock' 'RowExclusiveLock' absolute 1 1 ' '
BEGIN postgres_local.Confluence_locks 0
SET 'Confluence_ExclusiveLock' = 0
SET 'Confluence_RowShareLock' = 0
SET 'Confluence_SIReadLock' = 0
SET 'Confluence_ShareUpdateExclusiveLock' = 0
SET 'Confluence_AccessExclusiveLock' = 0
SET 'Confluence_AccessShareLock' = 0
SET 'Confluence_ShareRowExclusiveLock' = 0
SET 'Confluence_ShareLock' = 0
SET 'Confluence_RowExclusiveLock' = 0
END
CHART postgres_local.tx_wraparound_percent_towards_wraparound '' 'Percent towards wraparound' 'percent' 'tx_wraparound' 'postgres.percent_towards_wraparound' line 60049 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'percent_towards_wraparound' 'percent' absolute 1 1 ' '
BEGIN postgres_local.tx_wraparound_percent_towards_wraparound 0
SET 'percent_towards_wraparound' = 2
END
CHART postgres_local.postgres_db_stat_transactions '' 'Transactions on db: postgres' 'transactions/s' 'db postgres' 'postgres.db_stat_transactions' line 60010 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_xact_commit' 'committed' incremental 1 1 ' '
DIMENSION 'postgres_xact_rollback' 'rolled back' incremental 1 1 ' '
BEGIN postgres_local.postgres_db_stat_transactions 0
SET 'postgres_xact_commit' = 2177118
SET 'postgres_xact_rollback' = 774
END
CHART postgres_local.postgres_db_stat_tuple_returned '' 'Tuples returned from db: postgres' 'tuples/s' 'db postgres' 'postgres.db_stat_tuple_returned' line 60012 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_tup_returned' 'sequential' incremental 1 1 ' '
DIMENSION 'postgres_tup_fetched' 'bitmap' incremental 1 1 ' '
BEGIN postgres_local.postgres_db_stat_tuple_returned 0
SET 'postgres_tup_returned' = 1096071131
SET 'postgres_tup_fetched' = 15620182
END
CHART postgres_local.stat_bgwriter_alloc '' 'Buffers allocated' 'KiB/s' 'bgwriter' 'postgres.stat_bgwriter_alloc' line 60035 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'buffers_alloc' 'alloc' incremental 1 1024 ' '
BEGIN postgres_local.stat_bgwriter_alloc 0
SET 'buffers_alloc' = 247867736064
END
CHART postgres_local.checkpointer '' 'Checkpoints' 'writes' 'checkpointer' 'postgres.checkpointer' line 60034 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'checkpoint_scheduled' 'scheduled' incremental 1 1 ' '
DIMENSION 'checkpoint_requested' 'requested' incremental 1 1 ' '
BEGIN postgres_local.checkpointer 0
SET 'checkpoint_scheduled' = 215616
SET 'checkpoint_requested' = 0
END
CHART postgres_local.postgres_locks '' 'Locks on db: postgres' 'locks' 'db postgres' 'postgres.db_locks' line 60047 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_ExclusiveLock' 'ExclusiveLock' absolute 1 1 ' '
DIMENSION 'postgres_RowShareLock' 'RowShareLock' absolute 1 1 ' '
DIMENSION 'postgres_SIReadLock' 'SIReadLock' absolute 1 1 ' '
DIMENSION 'postgres_ShareUpdateExclusiveLock' 'ShareUpdateExclusiveLock' absolute 1 1 ' '
DIMENSION 'postgres_AccessExclusiveLock' 'AccessExclusiveLock' absolute 1 1 ' '
DIMENSION 'postgres_AccessShareLock' 'AccessShareLock' absolute 1 1 ' '
DIMENSION 'postgres_ShareRowExclusiveLock' 'ShareRowExclusiveLock' absolute 1 1 ' '
DIMENSION 'postgres_ShareLock' 'ShareLock' absolute 1 1 ' '
DIMENSION 'postgres_RowExclusiveLock' 'RowExclusiveLock' absolute 1 1 ' '
BEGIN postgres_local.postgres_locks 0
SET 'postgres_ExclusiveLock' = 0
SET 'postgres_RowShareLock' = 0
SET 'postgres_SIReadLock' = 0
SET 'postgres_ShareUpdateExclusiveLock' = 0
SET 'postgres_AccessExclusiveLock' = 0
SET 'postgres_AccessShareLock' = 1
SET 'postgres_ShareRowExclusiveLock' = 0
SET 'postgres_ShareLock' = 0
SET 'postgres_RowExclusiveLock' = 0
END
CHART postgres_local.Confluence_db_stat_transactions '' 'Transactions on db: Confluence' 'transactions/s' 'db Confluence' 'postgres.db_stat_transactions' line 60002 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_xact_commit' 'committed' incremental 1 1 ' '
DIMENSION 'Confluence_xact_rollback' 'rolled back' incremental 1 1 ' '
BEGIN postgres_local.Confluence_db_stat_transactions 0
SET 'Confluence_xact_commit' = 2104351066
SET 'Confluence_xact_rollback' = 2585842
END
CHART postgres_local.Confluence_db_stat_temp_files '' 'Temp files written to disk: Confluence' 'files' 'db Confluence' 'postgres.db_stat_temp_files' line 60007 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_temp_files' 'files' incremental 1 1 ' '
BEGIN postgres_local.Confluence_db_stat_temp_files 0
SET 'Confluence_temp_files' = 0
END
CHART postgres_local.autovacuum '' 'Autovacuum workers' 'workers' 'autovacuum' 'postgres.autovacuum' line 60044 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'analyze' 'analyze' absolute 1 1 ' '
DIMENSION 'vacuum' 'vacuum' absolute 1 1 ' '
DIMENSION 'vacuum_analyze' 'vacuum analyze' absolute 1 1 ' '
DIMENSION 'vacuum_freeze' 'vacuum freeze' absolute 1 1 ' '
DIMENSION 'brin_summarize' 'brin summarize' absolute 1 1 ' '
BEGIN postgres_local.autovacuum 0
SET 'analyze' = 0
SET 'vacuum' = 0
SET 'vacuum_analyze' = 0
SET 'vacuum_freeze' = 0
SET 'brin_summarize' = 0
END
CHART postgres_local.postgres_db_stat_blks '' 'Disk blocks reads from db: postgres' 'reads/s' 'db postgres' 'postgres.db_stat_blks' line 60013 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_blks_read' 'disk' incremental 1 1 ' '
DIMENSION 'postgres_blks_hit' 'cache' incremental 1 1 ' '
BEGIN postgres_local.postgres_db_stat_blks 0
SET 'postgres_blks_read' = 327807
SET 'postgres_blks_hit' = 79023500
END
CHART postgres_local.Confluence_db_stat_blks '' 'Disk blocks reads from db: Confluence' 'reads/s' 'db Confluence' 'postgres.db_stat_blks' line 60005 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_blks_read' 'disk' incremental 1 1 ' '
DIMENSION 'Confluence_blks_hit' 'cache' incremental 1 1 ' '
BEGIN postgres_local.Confluence_db_stat_blks 0
SET 'Confluence_blks_read' = 241340858
SET 'Confluence_blks_hit' = 167786366393
END
CHART postgres_local.stat_bgwriter_backend_fsync '' 'Fsync by backend' 'times' 'bgwriter' 'postgres.stat_bgwriter_backend_fsync' line 60038 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'buffers_backend_fsync' 'backend fsync' incremental 1 1 ' '
BEGIN postgres_local.stat_bgwriter_backend_fsync 0
SET 'buffers_backend_fsync' = 0
END
CHART postgres_local.wal_writes '' 'Write-Ahead Logs' 'KiB/s' 'wal_writes' 'postgres.wal_writes' line 60032 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'wal_writes' 'writes' incremental 1 1024 ' '
BEGIN postgres_local.wal_writes 0
SET 'wal_writes' = 291405861432
END
CHART postgres_local.tx_wraparound_oldest_current_xid '' 'Oldest current XID' 'xid' 'tx_wraparound' 'postgres.tx_wraparound_oldest_current_xid' line 60046 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'oldest_current_xid' 'xid' absolute 1 1 ' '
BEGIN postgres_local.tx_wraparound_oldest_current_xid 0
SET 'oldest_current_xid' = 49807441
END
CHART postgres_local.database_size '' 'Database size' 'MiB' 'database size' 'postgres.db_size' stacked 60024 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'postgres_size' 'postgres' absolute 1 1048576 ' '
DIMENSION 'Confluence_size' 'Confluence' absolute 1 1048576 ' '
BEGIN postgres_local.database_size 0
SET 'postgres_size' = 7027224
SET 'Confluence_size' = 3636386328
END
CHART postgres_local.backend_process '' 'Current Backend Processes' 'processes' 'backend processes' 'postgres.backend_process' line 60025 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'backends_active' 'active' absolute 1 1 ' '
DIMENSION 'backends_idle' 'idle' absolute 1 1 ' '
BEGIN postgres_local.backend_process 0
SET 'backends_active' = 21
SET 'backends_idle' = 0
END
CHART postgres_local.stat_bgwriter_checkpoint '' 'Buffers written during checkpoints' 'KiB/s' 'bgwriter' 'postgres.stat_bgwriter_checkpoint' line 60036 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'buffers_checkpoint' 'checkpoint' incremental 1 1024 ' '
BEGIN postgres_local.stat_bgwriter_checkpoint 0
SET 'buffers_checkpoint' = 265283649536
END
CHART postgres_local.stat_bgwriter_bgwriter '' 'Buffers written by the background writer' 'KiB/s' 'bgwriter' 'postgres.bgwriter_bgwriter' line 60039 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'buffers_clean' 'clean' incremental 1 1024 ' '
BEGIN postgres_local.stat_bgwriter_bgwriter 0
SET 'buffers_clean' = 6839205888
END
CHART postgres_local.Confluence_db_stat_temp_bytes '' 'Temp files written to disk: Confluence' 'KiB/s' 'db Confluence' 'postgres.db_stat_temp_bytes' line 60006 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'Confluence_temp_bytes' 'size' incremental 1 1024 ' '
BEGIN postgres_local.Confluence_db_stat_temp_bytes 0
SET 'Confluence_temp_bytes' = 0
END
CHART postgres_local.stat_bgwriter_backend '' 'Buffers written directly by a backend' 'KiB/s' 'bgwriter' 'postgres.stat_bgwriter_backend' line 60037 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'buffers_backend' 'backend' incremental 1 1024 ' '
BEGIN postgres_local.stat_bgwriter_backend 0
SET 'buffers_backend' = 28070150144
END
CHART postgres_local.stat_bgwriter_maxwritten '' 'Too many buffers written' 'times' 'bgwriter' 'postgres.stat_bgwriter_maxwritten' line 60040 1 '' 'python.d.plugin' 'postgres'
DIMENSION 'maxwritten_clean' 'maxwritten' incremental 1 1 ' '
BEGIN postgres_local.stat_bgwriter_maxwritten 0
SET 'maxwritten_clean' = 960
END
BEGIN netdata.runtime_postgres_local 0
SET run_time = 32
END
2022-01-17 11:22:25: python.d DEBUG: postgres[socket] : update => [OK] (elapsed time: 32, failed retries in a row: 0)
BEGIN postgres_local.Confluence_db_stat_tuple_returned 999433
SET 'Confluence_tup_returned' = 160153894604
SET 'Confluence_tup_fetched' = 82415304808
END
BEGIN postgres_local.Confluence_db_stat_tuple_write 999433
SET 'Confluence_tup_inserted' = 30152083
END
BEGIN postgres_local.backend_usage 999433
SET 'used' = 21
END
BEGIN postgres_local.postgres_db_stat_connections 999433
END
BEGIN postgres_local.postgres_db_stat_temp_files 999433
END
BEGIN postgres_local.Confluence_db_stat_connections 999433
END
BEGIN postgres_local.postgres_db_stat_temp_bytes 999433
END
BEGIN postgres_local.postgres_db_stat_tuple_write 999433
END
BEGIN postgres_local.Confluence_locks 999433
END
BEGIN postgres_local.tx_wraparound_percent_towards_wraparound 999433
END
BEGIN postgres_local.postgres_db_stat_transactions 999433
SET 'postgres_xact_commit' = 2177129
END
BEGIN postgres_local.postgres_db_stat_tuple_returned 999433
SET 'postgres_tup_returned' = 1096071679
SET 'postgres_tup_fetched' = 15620730
END
BEGIN postgres_local.stat_bgwriter_alloc 999433
END
BEGIN postgres_local.checkpointer 999433
END
BEGIN postgres_local.postgres_locks 999433
END
BEGIN postgres_local.Confluence_db_stat_transactions 999433
SET 'Confluence_xact_commit' = 2104351077
END
BEGIN postgres_local.Confluence_db_stat_temp_files 999433
END
BEGIN postgres_local.autovacuum 999433
SET 'analyze' = 0
SET 'vacuum' = 0
END
BEGIN postgres_local.postgres_db_stat_blks 999433
SET 'postgres_blks_hit' = 79024267
END
BEGIN postgres_local.Confluence_db_stat_blks 999433
SET 'Confluence_blks_hit' = 167786366422
END
BEGIN postgres_local.stat_bgwriter_backend_fsync 999433
END
BEGIN postgres_local.wal_writes 999433
SET 'wal_writes' = 291405867344
END
BEGIN postgres_local.tx_wraparound_oldest_current_xid 999433
SET 'oldest_current_xid' = 49807443
END
BEGIN postgres_local.database_size 999433
END
BEGIN postgres_local.backend_process 999433
END
BEGIN postgres_local.stat_bgwriter_checkpoint 999433
END
BEGIN postgres_local.stat_bgwriter_bgwriter 999433
END
BEGIN postgres_local.Confluence_db_stat_temp_bytes 999433
END
BEGIN postgres_local.stat_bgwriter_backend 999433
END
BEGIN postgres_local.stat_bgwriter_maxwritten 999433
END
BEGIN netdata.runtime_postgres_local 999433
SET run_time = 29
END
2022-01-17 11:22:26: python.d DEBUG: postgres[socket] : update => [OK] (elapsed time: 29, failed retries in a row: 0)
^C2022-01-17 11:22:26: python.d INFO: plugin[main] : exiting from main..
I cannot find any Chart graphics in the dashboard.
Am I missing anything?
Thanks
Bernd
Hi @Bernd ,
I’d just like to check, did you restart the Netdata agent?
If you restart the agent and postgres doesn’t appear could you please share the error.log with me?
Thanks!
Thank you for your response!
Yes I did restart and refresh the site as well
in Error log is this:
2022-01-17 14:35:54: netdata INFO  : MAIN : TIMEZONE: using the contents of /etc/timezone
2022-01-17 14:35:54: netdata INFO  : MAIN : TIMEZONE: fixed as 'Europe/Berlin'
2022-01-17 14:35:54: netdata INFO  : MAIN : SIGNAL: Not enabling reaper
2022-01-17 14:35:54: netdata ERROR : MAIN : LISTENER: IPv4 bind() on ip '0.0.0.0' port 19999, socktype 1 failed. (errno 98, Address in use)
2022-01-17 14:35:54: netdata ERROR : MAIN : LISTENER: Cannot bind to ip '0.0.0.0', port 19999
2022-01-17 14:35:54: netdata ERROR : MAIN : LISTENER: IPv6 bind() on ip '::' port 19999, socktype 1 failed. (errno 98, Address in use)
2022-01-17 14:35:54: netdata ERROR : MAIN : LISTENER: Cannot bind to ip '::', port 19999
2022-01-17 14:35:54: netdata FATAL : MAIN : LISTENER: Cannot listen on any API socket. Exiting... # : Invalid argument
2022-01-17 14:35:54: netdata INFO  : MAIN : EXIT: netdata prepares to exit with code 1...
2022-01-17 14:35:54: netdata INFO  : MAIN : EXIT: cleaning up the database...
2022-01-17 14:35:54: netdata INFO  : MAIN : Cleaning up database [0 hosts(s)]...
2022-01-17 14:35:54: netdata INFO  : MAIN : EXIT: removing netdata PID file '/opt/netdata/var/run/netdata/netdata.pid'...
2022-01-17 14:35:54: netdata ERROR : MAIN : EXIT: cannot unlink pidfile '/opt/netdata/var/run/netdata/netdata.pid'. (errno 2, No such file or directory)
2022-01-17 14:35:54: netdata INFO  : MAIN : EXIT: all done - netdata is now exiting - bye bye...
2022-01-17 14:36:02: netdata INFO  : MAIN : TIMEZONE: using the contents of /etc/timezone
2022-01-17 14:36:02: netdata INFO  : MAIN : TIMEZONE: fixed as 'Europe/Berlin'
2022-01-17 14:36:02: netdata INFO  : MAIN : SIGNAL: Not enabling reaper
2022-01-17 14:36:02: netdata ERROR : MAIN : LISTENER: IPv4 bind() on ip '0.0.0.0' port 19999, socktype 1 failed. (errno 98, Address in use)
2022-01-17 14:36:02: netdata ERROR : MAIN : LISTENER: Cannot bind to ip '0.0.0.0', port 19999
2022-01-17 14:36:02: netdata ERROR : MAIN : LISTENER: IPv6 bind() on ip '::' port 19999, socktype 1 failed. (errno 98, Address in use)
2022-01-17 14:36:02: netdata ERROR : MAIN : LISTENER: Cannot bind to ip '::', port 19999
2022-01-17 14:36:02: netdata FATAL : MAIN : LISTENER: Cannot listen on any API socket. Exiting... # : Invalid argument
2022-01-17 14:36:02: netdata INFO  : MAIN : EXIT: netdata prepares to exit with code 1...
2022-01-17 14:36:02: netdata INFO  : MAIN : EXIT: cleaning up the database...
2022-01-17 14:36:02: netdata INFO  : MAIN : Cleaning up database [0 hosts(s)]...
2022-01-17 14:36:02: netdata INFO  : MAIN : EXIT: removing netdata PID file '/opt/netdata/var/run/netdata/netdata.pid'...
2022-01-17 14:36:02: netdata ERROR : MAIN : EXIT: cannot unlink pidfile '/opt/netdata/var/run/netdata/netdata.pid'. (errno 2, No such file or directory)
2022-01-17 14:36:02: netdata INFO  : MAIN : EXIT: all done - netdata is now exiting - bye bye...
2022-01-17 14:36:33: netdata INFO  : MAIN : TIMEZONE: using the contents of /etc/timezone
2022-01-17 14:36:33: netdata INFO  : MAIN : TIMEZONE: fixed as 'Europe/Berlin'
2022-01-17 14:36:33: netdata INFO  : MAIN : SIGNAL: Not enabling reaper
2022-01-17 14:36:33: netdata ERROR : MAIN : LISTENER: IPv4 bind() on ip '0.0.0.0' port 19999, socktype 1 failed. (errno 98, Address in use)
2022-01-17 14:36:33: netdata ERROR : MAIN : LISTENER: Cannot bind to ip '0.0.0.0', port 19999
2022-01-17 14:36:33: netdata ERROR : MAIN : LISTENER: IPv6 bind() on ip '::' port 19999, socktype 1 failed. (errno 98, Address in use)
2022-01-17 14:36:33: netdata ERROR : MAIN : LISTENER: Cannot bind to ip '::', port 19999
2022-01-17 14:36:33: netdata FATAL : MAIN : LISTENER: Cannot listen on any API socket. Exiting... # : Invalid argument
2022-01-17 14:36:33: netdata INFO  : MAIN : EXIT: netdata prepares to exit with code 1...
2022-01-17 14:36:33: netdata INFO  : MAIN : EXIT: cleaning up the database...
2022-01-17 14:36:33: netdata INFO  : MAIN : Cleaning up database [0 hosts(s)]...
2022-01-17 14:36:33: netdata INFO  : MAIN : EXIT: removing netdata PID file '/opt/netdata/var/run/netdata/netdata.pid'...
2022-01-17 14:36:33: netdata ERROR : MAIN : EXIT: cannot unlink pidfile '/opt/netdata/var/run/netdata/netdata.pid'. (errno 2, No such file or directory)
2022-01-17 14:36:33: netdata INFO  : MAIN : EXIT: all done - netdata is now exiting - bye bye...
The errorlog has “exiting” at last. But is running …
Because I did a service restart netdata did try to early, the port was not free enough. but this shall not the problem
Thanks for the context @Bernd
Did you configure postgres as described in our documentation?
I also found this reply from one of our team members with some steps you can follow in order to safely restart the service.
What can I say? You have hit the nail on the head.
The hint with killall netdata was spot on.
Apparently the service restart did not work completely.
Unfortunately I didn’t check for leftover processes before.
Anyway - the charts of postgres are there now!
Thanks! @georgia
–Bernd
Happy it worked for you Bernd!
Have a good one!
