Seems to happen with both the stable and nightly version
error.log
2023-11-23 19:15:07:
netdata INFO : MAIN : Netdata agent version "v1.43.2" is starting
netdata INFO : MAIN : IEEE754: system is using IEEE754 DOUBLE PRECISION values
netdata INFO : MAIN : TIMEZONE: using the contents of /etc/timezone
netdata INFO : MAIN : TIMEZONE: fixed as 'America/New_York'
netdata INFO : MAIN : NETDATA STARTUP: next: initialize ML
netdata INFO : MAIN : ml database version is 2 (no migration needed)
netdata INFO : MAIN : NETDATA STARTUP: in 8 ms, initialize ML - next: initialize signals
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize signals - next: initialize static threads
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize static threads - next: initialize web server
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize web server - next: initialize h2o server
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize h2o server - next: set resource limits
netdata INFO : MAIN : resources control: allowed file descriptors: soft = 1024, max = 524288
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, set resource limits - next: become daemon
netdata INFO : MAIN : Out-Of-Memory (OOM) score is already set to the wanted value 0
netdata INFO : MAIN : Adjusted netdata scheduling policy to batch (3), with priority 0.
netdata INFO : MAIN : Running with process scheduling policy 'batch', nice level 19
netdata INFO : MAIN : I am root, so checking permissions
netdata ERROR : MAIN : Cannot chown directory '/var/lib/netdata/cloud.d' to 117:125 (errno 2, No such file or directory)
netdata INFO : MAIN : netdata started on pid 2140505.
netdata INFO : MAIN : NETDATA STARTUP: in 3 ms, become daemon - next: initialize threads after fork
netdata INFO : MAIN : Set threads stack size to 8388608 bytes
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize threads after fork - next: initialize registry
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, initialize registry - next: fork the spawn server
netdata INFO : MAIN : Initializing spawn client.
netdata INFO : MAIN : NETDATA STARTUP: in 5 ms, fork the spawn server - next: collecting system info
netdata INFO : MAIN : NETDATA_CONTAINER_OS_NAME=none
netdata INFO : MAIN : NETDATA_CONTAINER_OS_ID=none
netdata INFO : MAIN : NETDATA_CONTAINER_OS_ID_LIKE=none
netdata INFO : MAIN : NETDATA_CONTAINER_OS_VERSION=none
netdata INFO : MAIN : NETDATA_CONTAINER_OS_VERSION_ID=none
netdata INFO : MAIN : NETDATA_CONTAINER_OS_DETECTION=none
netdata INFO : MAIN : NETDATA_CONTAINER_IS_OFFICIAL_IMAGE=false
netdata INFO : MAIN : NETDATA_HOST_OS_NAME=Ubuntu
netdata INFO : MAIN : NETDATA_HOST_OS_ID=ubuntu
netdata INFO : MAIN : NETDATA_HOST_OS_ID_LIKE=debian
netdata INFO : MAIN : NETDATA_HOST_OS_VERSION=22.04.3 LTS (Jammy Jellyfish)
netdata INFO : MAIN : NETDATA_HOST_OS_VERSION_ID=22.04
netdata INFO : MAIN : NETDATA_HOST_OS_DETECTION=/etc/os-release
netdata INFO : MAIN : NETDATA_HOST_IS_K8S_NODE=false
netdata INFO : MAIN : NETDATA_SYSTEM_KERNEL_NAME=Linux
netdata INFO : MAIN : NETDATA_SYSTEM_KERNEL_VERSION=6.2.0-37-generic
netdata INFO : MAIN : NETDATA_SYSTEM_ARCHITECTURE=x86_64
netdata INFO : MAIN : NETDATA_SYSTEM_VIRTUALIZATION=none
netdata INFO : MAIN : NETDATA_SYSTEM_VIRT_DETECTION=systemd-detect-virt
netdata INFO : MAIN : NETDATA_SYSTEM_CONTAINER=none
netdata INFO : MAIN : NETDATA_SYSTEM_CONTAINER_DETECTION=systemd-detect-virt
netdata INFO : MAIN : NETDATA_SYSTEM_CPU_LOGICAL_CPU_COUNT=12
netdata INFO : MAIN : NETDATA_SYSTEM_CPU_VENDOR=AuthenticAMD
netdata INFO : MAIN : NETDATA_SYSTEM_CPU_MODEL=AMD Ryzen 5 4600G with Radeon Graphics
netdata INFO : MAIN : NETDATA_SYSTEM_CPU_FREQ=4308000000
netdata INFO : MAIN : NETDATA_SYSTEM_CPU_DETECTION=lscpu
netdata INFO : MAIN : NETDATA_SYSTEM_TOTAL_RAM=32975933440
netdata INFO : MAIN : NETDATA_SYSTEM_RAM_DETECTION=procfs
netdata INFO : MAIN : NETDATA_SYSTEM_TOTAL_DISK_SIZE=12380445278208
netdata INFO : MAIN : NETDATA_SYSTEM_DISK_DETECTION=sysfs
netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_TYPE=unknown
netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_INSTANCE_TYPE=unknown
netdata INFO : MAIN : NETDATA_INSTANCE_CLOUD_INSTANCE_REGION=unknown
netdata INFO : MAIN : NETDATA STARTUP: in 316 ms, collecting system info - next: initialize RRD structures
netdata INFO : MAIN : SQLite database /var/cache/netdata/netdata-meta.db initialization
netdata INFO : MAIN : metadata database version is 14 (no migration needed)
netdata INFO : MAIN : SQLite database initialization completed
netdata INFO : MAIN : SQLite database /var/cache/netdata/context-meta.db initialization
netdata INFO : MAIN : context database version is 1 (no migration needed)
netdata INFO : MAIN : Cannot open the file /var/lib/netdata/health.silencers.json, so Netdata will work with the default health configuration.
netdata INFO : MAIN : CONFIG: cannot load user config '/etc/netdata/stream.conf'. Will try stock config.
netdata INFO : MAIN : DBENGINE: Initializing ...
netdata INFO : DBENGINIT[0] : thread created with task id 2140663
netdata INFO : DBENGINIT[0] : set name of thread 2140663 to DBENGINIT[0]
netdata INFO : DBENGINIT[2] : thread created with task id 2140665
netdata INFO : DBENGINIT[2] : set name of thread 2140665 to DBENGINIT[2]
netdata INFO : DBENGINIT[1] : thread created with task id 2140664
netdata INFO : DBENGINIT[1] : set name of thread 2140664 to DBENGINIT[1]
netdata INFO : DBENGINIT[2] : DBENGINE: found 2 files in path /var/cache/netdata/dbengine-tier2
netdata INFO : DBENGINIT[0] : DBENGINE: found 32 files in path /var/cache/netdata/dbengine
netdata INFO : DBENGINIT[1] : DBENGINE: found 8 files in path /var/cache/netdata/dbengine-tier1
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000001.ndf".
netdata INFO : DBENGINIT[2] : DBENGINE: initializing data file "/var/cache/netdata/dbengine-tier2/datafile-1-0000000001.ndf".
netdata INFO : DBENGINIT[1] : DBENGINE: initializing data file "/var/cache/netdata/dbengine-tier1/datafile-1-0000000001.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000001.ndf" initialized (size:5390336).
netdata INFO : DBENGINIT[2] : DBENGINE: data file "/var/cache/netdata/dbengine-tier2/datafile-1-0000000001.ndf" initialized (size:987136).
netdata INFO : DBENGINIT[1] : DBENGINE: data file "/var/cache/netdata/dbengine-tier1/datafile-1-0000000001.ndf" initialized (size:4198400).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000001.njfv2'
netdata INFO : DBENGINIT[1] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine-tier1/journalfile-1-0000000001.njfv2'
netdata INFO : DBENGINIT[2] : DBENGINE: loading journal file '/var/cache/netdata/dbengine-tier2/journalfile-1-0000000001.njf'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000001.njfv2' loaded, size: 0.71 MiB, metrics: 4.57 k, mmap: 0.18 ms, validate: 0.14 ms
netdata INFO : DBENGINIT[1] : DBENGINE: journal v2 '/var/cache/netdata/dbengine-tier1/journalfile-1-0000000001.njfv2' loaded, size: 0.97 MiB, metrics: 4.60 k, mmap: 0.13 ms, validate: 0.06 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000002.ndf".
netdata INFO : DBENGINIT[1] : DBENGINE: initializing data file "/var/cache/netdata/dbengine-tier1/datafile-1-0000000002.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000002.ndf" initialized (size:5373952).
netdata INFO : DBENGINIT[1] : DBENGINE: data file "/var/cache/netdata/dbengine-tier1/datafile-1-0000000002.ndf" initialized (size:2387968).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000002.njfv2'
netdata INFO : DBENGINIT[1] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine-tier1/journalfile-1-0000000002.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000002.njfv2' loaded, size: 0.64 MiB, metrics: 4.94 k, mmap: 0.11 ms, validate: 0.17 ms
netdata INFO : DBENGINIT[1] : DBENGINE: journal v2 '/var/cache/netdata/dbengine-tier1/journalfile-1-0000000002.njfv2' loaded, size: 0.65 MiB, metrics: 5.39 k, mmap: 0.24 ms, validate: 0.05 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000003.ndf".
netdata INFO : DBENGINIT[1] : DBENGINE: initializing data file "/var/cache/netdata/dbengine-tier1/datafile-1-0000000003.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000003.ndf" initialized (size:5398528).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000003.njfv2'
netdata INFO : DBENGINIT[1] : DBENGINE: data file "/var/cache/netdata/dbengine-tier1/datafile-1-0000000003.ndf" initialized (size:262144).
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000003.njfv2' loaded, size: 0.64 MiB, metrics: 4.77 k, mmap: 0.11 ms, validate: 0.09 ms
netdata INFO : DBENGINIT[1] : DBENGINE: loading journal file '/var/cache/netdata/dbengine-tier1/journalfile-1-0000000003.njf'
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000004.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000004.ndf" initialized (size:5373952).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000004.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000004.njfv2' loaded, size: 0.63 MiB, metrics: 4.74 k, mmap: 0.11 ms, validate: 0.04 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000005.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000005.ndf" initialized (size:5386240).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000005.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000005.njfv2' loaded, size: 0.65 MiB, metrics: 4.81 k, mmap: 0.11 ms, validate: 0.04 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000006.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000006.ndf" initialized (size:5382144).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000006.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000006.njfv2' loaded, size: 0.64 MiB, metrics: 4.92 k, mmap: 0.09 ms, validate: 0.03 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000007.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000007.ndf" initialized (size:5390336).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000007.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000007.njfv2' loaded, size: 0.63 MiB, metrics: 4.73 k, mmap: 0.08 ms, validate: 0.04 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000008.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000008.ndf" initialized (size:5386240).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000008.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000008.njfv2' loaded, size: 0.64 MiB, metrics: 4.77 k, mmap: 0.09 ms, validate: 0.03 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000009.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000009.ndf" initialized (size:5378048).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000009.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000009.njfv2' loaded, size: 0.65 MiB, metrics: 4.88 k, mmap: 0.09 ms, validate: 0.04 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000010.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000010.ndf" initialized (size:5660672).
netdata INFO : DBENGINIT[0] : DBENGINE: checking integrity of '/var/cache/netdata/dbengine/journalfile-1-0000000010.njfv2'
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 '/var/cache/netdata/dbengine/journalfile-1-0000000010.njfv2' loaded, size: 0.75 MiB, metrics: 5.50 k, mmap: 0.09 ms, validate: 0.04 ms
netdata INFO : DBENGINIT[0] : DBENGINE: initializing data file "/var/cache/netdata/dbengine/datafile-1-0000000011.ndf".
netdata INFO : DBENGINIT[0] : DBENGINE: data file "/var/cache/netdata/dbengine/datafile-1-0000000011.ndf" initialized (size:4096).
netdata INFO : DBENGINIT[0] : DBENGINE: loading journal file '/var/cache/netdata/dbengine/journalfile-1-0000000011.njf'
netdata INFO : DBENGINIT[0] : DBENGINE: journal file '/var/cache/netdata/dbengine/journalfile-1-0000000011.njf' loaded (size:4096).
netdata INFO : DBENGINIT[0] : DBENGINE: populating retention to MRG from 11 journal files of tier 0, using 4 threads...
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 of tier 0, datafile 10 populated, size: 0.75 MiB, metrics: 5.50 k, 19.08 ms
netdata INFO : DBENGINIT[0] : DBENGINE: journal v2 of tier 0, datafile 1 populated, size: 0.71 MiB, metrics: 4.57 k, 7.87 ms
netdata INFO : DBENGINIT[0] : thread with task id 2140663 finished
netdata INFO : DBENGINIT[1] : DBENGINE: journal file '/var/cache/netdata/dbengine-tier1/journalfile-1-0000000003.njf' loaded (size:262144).
netdata INFO : DBENGINIT[1] : DBENGINE: populating retention to MRG from 3 journal files of tier 1, using 3 threads...
netdata INFO : DBENGINIT[1] : DBENGINE: journal v2 of tier 1, datafile 2 populated, size: 0.65 MiB, metrics: 5.39 k, 4.30 ms
netdata INFO : DBENGINIT[2] : DBENGINE: journal file '/var/cache/netdata/dbengine-tier2/journalfile-1-0000000001.njf' loaded (size:602112).
netdata INFO : DBENGINIT[2] : DBENGINE: populating retention to MRG from 1 journal files of tier 2, using 1 threads...
netdata INFO : DBENGINIT[2] : thread with task id 2140665 finished
netdata INFO : DBENGINIT[1] : DBENGINE: journal v2 of tier 1, datafile 1 populated, size: 0.97 MiB, metrics: 4.60 k, 3.55 ms
netdata INFO : DBENGINIT[1] : thread with task id 2140664 finished
netdata INFO : UV_WORKER[2] : DBENGINE: journal v2 of tier 0, datafile 3 populated, size: 0.64 MiB, metrics: 4.77 k, 4.53 ms
netdata INFO : UV_WORKER[4] : DBENGINE: journal v2 of tier 0, datafile 5 populated, size: 0.65 MiB, metrics: 4.81 k, 4.50 ms
netdata INFO : UV_WORKER[3] : DBENGINE: journal v2 of tier 0, datafile 4 populated, size: 0.63 MiB, metrics: 4.74 k, 5.37 ms
netdata INFO : UV_WORKER[1] : DBENGINE: journal v2 of tier 0, datafile 2 populated, size: 0.64 MiB, metrics: 4.94 k, 5.53 ms
netdata INFO : UV_WORKER[4] : DBENGINE: journal v2 of tier 0, datafile 7 populated, size: 0.63 MiB, metrics: 4.73 k, 2.87 ms
netdata INFO : UV_WORKER[2] : DBENGINE: journal v2 of tier 0, datafile 6 populated, size: 0.64 MiB, metrics: 4.92 k, 3.28 ms
netdata INFO : UV_WORKER[1] : DBENGINE: journal v2 of tier 0, datafile 9 populated, size: 0.65 MiB, metrics: 4.88 k, 2.77 ms
netdata INFO : UV_WORKER[3] : DBENGINE: journal v2 of tier 0, datafile 8 populated, size: 0.64 MiB, metrics: 4.77 k, 3.00 ms
netdata INFO : MAIN : DBENGINE: tier 0 is ready for data collection and queries
netdata INFO : MAIN : DBENGINE: tier 1 is ready for data collection and queries
netdata INFO : MAIN : DBENGINE: tier 2 is ready for data collection and queries
netdata INFO : METASYNC : Starting metadata sync thread with 2048 entries command queue
netdata INFO : MAIN : SQLite metadata sync initialization complete
netdata INFO : MAIN : Host 'hostname' (at registry as 'hostname') with guid '00000000' initialized, os 'linux', timezone 'America/New_York', tags '', program_name 'netdata', program_version 'v1.43.2', update every 1, memory mode dbengine, history entries 0, streaming disabled (to '' with api key ''), health enabled, cache_dir '/var/cache/netdata', alarms default handler '', alarms default recipient ''
netdata INFO : MAIN : Creating archived hosts
netdata INFO : MAIN : Created 0 archived hosts
netdata INFO : MAIN : ACLK sync initialization completed
netdata INFO : MAIN : NETDATA STARTUP: in 104 ms, initialize RRD structures - next: check for incomplete shutdown
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, check for incomplete shutdown - next: collect claiming info
netdata INFO : MAIN : Unable to load '/var/lib/netdata/cloud.d/claimed_id', setting state to AGENT_UNCLAIMED
netdata INFO : MAIN : NETDATA STARTUP: in 0 ms, collect claiming info - next: collect host labels
netdata INFO : ACLKSYNC : Starting ACLK synchronization thread
netdata INFO : MAIN : NETDATA STARTUP: in 13 ms, collect host labels - next: start the static threads
netdata INFO : P[timex] : thread created with task id 2140744
netdata INFO : P[timex] : set name of thread 2140744 to P[timex]
netdata INFO : P[idlejitter] : thread created with task id 2140745
netdata INFO : P[idlejitter] : set name of thread 2140745 to P[idlejitter]
netdata INFO : STATS_GLOBAL : thread created with task id 2140747
netdata INFO : STATS_GLOBAL : set name of thread 2140747 to STATS_GLOBAL
netdata INFO : HEALTH : thread created with task id 2140746
netdata INFO : HEALTH : set name of thread 2140746 to HEALTH
netdata INFO : STATS_WORKERS : thread created with task id 2140748
netdata INFO : STATS_WORKERS : set name of thread 2140748 to STATS_WORKERS
netdata INFO : STATS_SQLITE3 : thread created with task id 2140749
netdata INFO : STATS_SQLITE3 : set name of thread 2140749 to STATS_SQLITE3
netdata INFO : PLUGINSD : thread created with task id 2140750
netdata INFO : PLUGINSD : set name of thread 2140750 to PLUGINSD
netdata INFO : SERVICE : thread created with task id 2140751
netdata INFO : SERVICE : set name of thread 2140751 to SERVICE
netdata INFO : PD[charts.d] : thread created with task id 2140752
netdata INFO : PD[charts.d] : set name of thread 2140752 to PD[charts.d]
netdata INFO : PD[ebpf] : thread created with task id 2140754
netdata INFO : PD[ebpf] : set name of thread 2140754 to PD[ebpf]
netdata INFO : PD[debugfs] : thread created with task id 2140755
netdata INFO : PD[debugfs] : set name of thread 2140755 to PD[debugfs]
netdata INFO : STATSD_FLUSH : thread created with task id 2140753
netdata INFO : STATSD_FLUSH : set name of thread 2140753 to STATSD_FLUSH
netdata INFO : PD[nfacct] : thread created with task id 2140758
netdata INFO : PD[nfacct] : set name of thread 2140758 to PD[nfacct]
netdata INFO : EXPORTING : thread created with task id 2140756
netdata INFO : EXPORTING : set name of thread 2140756 to EXPORTING
netdata INFO : PD[systemd-jour : thread created with task id 2140760
netdata INFO : EXPORTING : CONFIG: cannot load user exporting config '/etc/netdata/exporting.conf'. Will try the stock version.
netdata INFO : WEB[1] : thread created with task id 2140763
netdata INFO : WEB[1] : set name of thread 2140763 to WEB[1]
netdata INFO : PD[apps] : thread created with task id 2140767
netdata INFO : PD[apps] : set name of thread 2140767 to PD[apps]
netdata INFO : PD[ioping] : thread created with task id 2140764
netdata INFO : PD[ioping] : set name of thread 2140764 to PD[ioping]
netdata INFO : PD[python.d] : thread created with task id 2140765
netdata INFO : PD[python.d] : set name of thread 2140765 to PD[python.d]
netdata INFO : ACLK_MAIN : thread created with task id 2140766
netdata INFO : ACLK_MAIN : set name of thread 2140766 to ACLK_MAIN
netdata INFO : PD[perf] : thread created with task id 2140761
netdata INFO : PD[perf] : set name of thread 2140761 to PD[perf]
netdata INFO : PD[debugfs] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/debugfs.plugin' running on pid 2140768
netdata INFO : PD[charts.d] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/charts.d.plugin' running on pid 2140757
netdata INFO : REPLAY[1] : thread created with task id 2140771
netdata INFO : REPLAY[1] : set name of thread 2140771 to REPLAY[1]
netdata INFO : WEB[1] : To use encryption it is necessary to set "ssl certificate" and "ssl key" in [web] !
netdata INFO : EXPORTING : No connector instances to activate
netdata INFO : EXPORTING : EXPORTING: no exporting connectors configured
netdata INFO : EXPORTING : cleaning up...
netdata INFO : EXPORTING : thread with task id 2140756 finished
netdata INFO : PD[systemd-jour : set name of thread 2140760 to PD[systemd-jour
netdata INFO : PD[ebpf] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/ebpf.plugin' running on pid 2140762
netdata INFO : P[proc] : thread created with task id 2140775
netdata INFO : P[proc] : set name of thread 2140775 to P[proc]
netdata INFO : PD[go.d] : thread created with task id 2140759
netdata INFO : PD[go.d] : set name of thread 2140759 to PD[go.d]
netdata INFO : P[tc] : thread created with task id 2140773
netdata INFO : P[tc] : set name of thread 2140773 to P[tc]
netdata INFO : PREDICT : thread created with task id 2140777
netdata INFO : PREDICT : set name of thread 2140777 to PREDICT
netdata INFO : P[diskspace] : thread created with task id 2140774
netdata INFO : P[diskspace] : set name of thread 2140774 to P[diskspace]
netdata INFO : DYNCFG : thread created with task id 2140772
netdata INFO : DYNCFG : set name of thread 2140772 to DYNCFG
netdata INFO : RRDCONTEXT : thread created with task id 2140769
netdata INFO : RRDCONTEXT : set name of thread 2140769 to RRDCONTEXT
netdata INFO : ACLK_MAIN : Waiting for Cloud to be enabled
netdata INFO : PD[apps] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/apps.plugin' running on pid 2140778
netdata INFO : TRAIN[0] : thread created with task id 2140779
netdata INFO : TRAIN[2] : thread created with task id 2140783
netdata INFO : TRAIN[2] : set name of thread 2140783 to TRAIN[2]
netdata INFO : P[proc netdev] : thread created with task id 2140780
netdata INFO : P[proc netdev] : set name of thread 2140780 to P[proc netdev]
netdata INFO : PD[nfacct] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/nfacct.plugin' running on pid 2140770
netdata INFO : MAIN : NETDATA STARTUP: in 6 ms, start the static threads - next: initialize commands API
netdata INFO : MAIN : Initializing command server.
netdata INFO : TRAIN[0] : set name of thread 2140779 to TRAIN[0]
netdata INFO : P[cgroups] : thread created with task id 2140776
netdata INFO : P[cgroups] : set name of thread 2140776 to P[cgroups]
netdata INFO : PD[python.d] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/python.d.plugin' running on pid 2140785
netdata INFO : TRAIN[1] : thread created with task id 2140781
netdata INFO : TRAIN[1] : set name of thread 2140781 to TRAIN[1]
netdata INFO : WEB[1] : starting worker 2
netdata INFO : TRAIN[3] : thread created with task id 2140784
netdata INFO : TRAIN[3] : set name of thread 2140784 to TRAIN[3]
netdata INFO : WEB[2] : thread created with task id 2140788
netdata INFO : WEB[2] : set name of thread 2140788 to WEB[2]
netdata INFO : WEB[2] : POLLFD: LISTENER: listening on 'tcp:0.0.0.0:19999'
netdata INFO : WEB[2] : POLLFD: LISTENER: listening on 'tcp:[::]:19999'
netdata INFO : PD[ioping] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/ioping.plugin' running on pid 2140787
netdata INFO : WEB[1] : starting worker 3
netdata ERROR : STATSD_FLUSH : LISTENER: IPv6 bind() on ip '::1' port 8125, socktype 1 failed. (errno 98, Address already in use)
netdata ERROR : STATSD_FLUSH : LISTENER: Cannot bind to ip '::1', port 8125
netdata INFO : WEB[1] : starting worker 4
netdata INFO : MAIN : NETDATA STARTUP: in 1 ms, initialize commands API - next: ready
netdata INFO : P[diskspace slo : thread created with task id 2140782
netdata INFO : P[diskspace slo : set name of thread 2140782 to P[diskspace slo
netdata INFO : WEB[4] : thread created with task id 2140791
netdata INFO : WEB[4] : set name of thread 2140791 to WEB[4]
netdata ERROR : STATSD_FLUSH : LISTENER: IPv4 bind() on ip '127.0.0.1' port 8125, socktype 1 failed. (errno 98, Address already in use)
netdata ERROR : STATSD_FLUSH : LISTENER: Cannot bind to ip '127.0.0.1', port 8125
netdata INFO : STATSD_FLUSH : LISTENER: Listen socket udp:[::1]:8125 opened successfully.
netdata INFO : STATSD_FLUSH : LISTENER: Listen socket udp:127.0.0.1:8125 opened successfully.
netdata INFO : WEB[1] : starting worker 5
netdata INFO : WEB[1] : starting worker 6
netdata INFO : MAIN : NETDATA STARTUP: completed in 461 ms. Enjoy real-time performance monitoring!
netdata INFO : MAIN : /usr/libexec/netdata/plugins.d/anonymous-statistics.sh 'START' '-' '-'
netdata INFO : WEB[5] : thread created with task id 2140793
netdata INFO : WEB[5] : set name of thread 2140793 to WEB[5]
netdata INFO : WEB[1] : POLLFD: LISTENER: listening on 'tcp:0.0.0.0:19999'
netdata INFO : WEB[1] : POLLFD: LISTENER: listening on 'tcp:[::]:19999'
netdata INFO : PD[systemd-jour : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/systemd-journal.plugin' running on pid 2140792
netdata INFO : STATSD_IN[1] : thread created with task id 2140795
netdata INFO : STATSD_IN[1] : set name of thread 2140795 to STATSD_IN[1]
netdata INFO : WEB[6] : thread created with task id 2140796
netdata INFO : PD[go.d] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/go.d.plugin' running on pid 2140794
netdata INFO : WEB[3] : thread created with task id 2140790
netdata INFO : WEB[3] : set name of thread 2140790 to WEB[3]
netdata INFO : WEB[3] : POLLFD: LISTENER: listening on 'tcp:0.0.0.0:19999'
netdata INFO : WEB[3] : POLLFD: LISTENER: listening on 'tcp:[::]:19999'
netdata INFO : WEB[6] : set name of thread 2140796 to WEB[6]
netdata INFO : STATSD_IN[1] : POLLFD: LISTENER: listening on 'udp:[::1]:8125'
netdata INFO : STATSD_IN[1] : POLLFD: LISTENER: listening on 'udp:127.0.0.1:8125'
netdata INFO : WEB[5] : POLLFD: LISTENER: listening on 'tcp:0.0.0.0:19999'
netdata INFO : WEB[5] : POLLFD: LISTENER: listening on 'tcp:[::]:19999'
netdata INFO : WEB[4] : POLLFD: LISTENER: listening on 'tcp:0.0.0.0:19999'
netdata INFO : WEB[4] : POLLFD: LISTENER: listening on 'tcp:[::]:19999'
netdata INFO : WEB[6] : POLLFD: LISTENER: listening on 'tcp:0.0.0.0:19999'
netdata INFO : WEB[6] : POLLFD: LISTENER: listening on 'tcp:[::]:19999'
netdata INFO : PD[perf] : PLUGINSD: 'host:hostname' connected to '/usr/libexec/netdata/plugins.d/perf.plugin' running on pid 2140789
netdata INFO : PD[perf] : PLUGINSD: plugin called DISABLE. Disabling it.
netdata INFO : PD[perf] : PLUGINSD: 'host:hostname', '/usr/libexec/netdata/plugins.d/perf.plugin' (pid 2140789) disconnected after 0 successful data collections (ENDs).
netdata ERROR : PD[perf] : child pid 2140789 exited with code 1.
netdata ERROR : PD[perf] : PLUGINSD: 'host:hostname', '/usr/libexec/netdata/plugins.d/perf.plugin' (pid 2140789) exited with error code 1 and haven't collected any data. Disabling it.
netdata INFO : PD[perf] : thread with task id 2140761 finished
netdata INFO : PD[ioping] : PLUGINSD: plugin called DISABLE. Disabling it.
netdata INFO : PD[ioping] : PLUGINSD: 'host:hostname', '/usr/libexec/netdata/plugins.d/ioping.plugin' (pid 2140787) disconnected after 0 successful data collections (ENDs).
netdata ERROR : PD[ioping] : child pid 2140787 exited with code 1.
netdata ERROR : PD[ioping] : PLUGINSD: 'host:hostname', '/usr/libexec/netdata/plugins.d/ioping.plugin' (pid 2140787) exited with error code 1 and haven't collected any data. Disabling it.
netdata INFO : PD[ioping] : thread with task id 2140764 finished
netdata INFO : PD[charts.d] : PLUGINSD: plugin called DISABLE. Disabling it.
netdata INFO : PD[charts.d] : PLUGINSD: 'host:hostname', '/usr/libexec/netdata/plugins.d/charts.d.plugin' (pid 2140757) disconnected after 0 successful data collections (ENDs).
netdata INFO : PD[charts.d] : PLUGINSD: 'host:hostname', '/usr/libexec/netdata/plugins.d/charts.d.plugin' (pid 2140757) does not generate useful output but it reports success (exits with 0). Will not start it again - it is now disabled..
netdata INFO : P[proc] : Using now_boottime_usec() for uptime (dt is 1 ms)
