Netdata icecast-kh error
Hi Guys,
I want to monitor my icecast-kh server with netdata, but not working.
Can I use icecast-kh with netdata?
log:
JSON decode error: ‘utf8’ codec can’t decode byte 0xf3 in position 1: invalid continuation byte
Thanks.
Hey @peppi001 :wave:
It means that the returned data is not valid JSON data.
What endpoint do you use? I see we collect data using /status-json.xsl.
i briefly checked icecast-kh and there is no status-json.xsl file.
See where are the files /json.xsl and /stats-json.xsl? · Issue #294 · karlheyes/icecast-kh · GitHub
As xsl files you can drop them in webroot and go ahead.
I guess you can create/find and copy them - it looks like that is how it works, you create a file with that returns stats data in JSON format and then just query it via HTTP.
I’m not an icecast user, i can’t help much.
I googled and found https://github.com/adel-s/radio/blob/master/icecast-kh/web/status-json.xsl
Thank you. I’ll try it.
