Nvidia-smi for a newbie
Hello
first of all i’m a real newbie !
so i have a netdata container running perfectly nut i’m trying to monitor my nvidia cards and following the Nvidia GPU monitoring with Netdata | Learn Netdata
i’m still experiencing problems : it seems that the conainer have no acces to nvidia-smi (and it’s installed and running )
i’m sure the problem comes from me but if anyone can help me
thank you
Hi, @Stephane_Caria. It is not possible to use nvisia-smi collector using the official Docker image.
There is GitHub - D34DC3N73R/netdata-glibc: netdata with glibc package for use with nvidia-docker2 (supported by a GitHub user) which is supposed to add the support, but I can’t say if it works or not.
Added a note in docs: nvidia-smi in a container limitation note by ilyam8 · Pull Request #13695 · netdata/netdata · GitHub
