pihole_status
Ad Filtering | Pi-hole
This alert monitors if Pi-hole’s ability of blocking unwanted domains is active.
- It is triggered in a warning state if pi-hole is disabled.
Troubleshooting Section
Rebuild the blocklist
To fix, run the command:root@netdata~ # pihole enable
This feature should be enabled. The whole point of Pi-hole!
