python.d_job_last_collected_secs
Netdata | python.d.plugin
The Netdata Agent also monitors itself, so this is an alert about the Netdata Python plugin. The Netdata Agent monitors the number of seconds since the last successful data collection for each of python plugin modules. This alert indicates that a specific module cannot reach the component it
monitors to collect metrics from it.
You can see all the modules that are orchestrated by the python.d.plugin in our GitHub repo
Troubleshooting section
Check the Netdata logs
You need to identify why the Agent cannot collect metrics for a specific job. Inspect the Agent logs for this
specific job.
Host machine:
root@netdata # tail -f /var/log/netdata/error.log | grep <job> OR <module_name>
Docker:
root@netdata # docker logs <netdata_container> 2>&1 | grep <job> OR <module_name>
Kubernetes:
Find the pod name of the node which produced the alert.
root@netdata # kubectl -n <namespace> get pod -o wide -l app=netdata | grep <node_name> -
Inspect it’s logs
root@netdata # kubectl logs -n <namespace> <pod_name> | grep <job> OR <module_name>
