ram_in_use
OS: Linux, FreeBSD
This alert shows the percentage of used RAM. If you receive this alert, there is high RAM utilization on the node. Running low on RAM memory, means that the performance of running applications might be affected.
If there is no
swapspace available, the OOM Killer can start killing processes. -
When a system runs out of RAM memory, it can store its inactive content in another storage’s partition (e.g. your main drive). The borrowed space is called
swapor “swap space”. -
The OOM Killer (Out of Memory Killer) is a process that the Linux Kernel uses when the system is critically low on RAM. As the name suggests, it has the duty to review all running processes and kill one or more of them in order to free up RAM memory and keep the system running.1
References and Sources
Troubleshooting section:
Check per-process RAM usage to find the top consumers
Linux
Use top:
root@netdata~ # top -b -o +%MEM | head -n 22
Here, you can see which processes are the main RAM consumers on the %MEM column (it is calculated in percentage).
Note: It would be helpful to close any of the main consumer processes, but Netdata strongly suggests knowing exactly what processes your are closing and being certain that they are not necessary.
FreeBSD
Use top:
root@netdata~ # top -b -o res | head -n 22
Here, you can see which processes are the main RAM consumers on the RES column (it is calculated in percentage).
