setting up netdata on truenas collecting data from proxmox agent without netdata cloud
I try to stream netdata from a netdata agent (child) installed on a proxmox node to a netdata agent (parent) running as a Truenas app (Truenas SCALE on another proxmox node ). The Trunas App netdata should become the central netdata instance (parent) where I should see all other agents (childs) reporting to (proxmox nodes, VMs,LXCs), e.g. under tab “nodes”. Parents and children are within the same LAN.
On the Truenas app netdata (parent: tn-pve02) I have configured netdata.conf
[web]
bind to = 0.0.0.0
hostname = tn-pve02
…and also there in: /etc/netdata/stream.conf
[stream]
enabled = yes
bind to = 0.0.0.0
default memory mode = save
[pve02b-child]
enabled = yes
allow from = *
default history = 3600
multiple connections = allow
api key = 00000000-0000-0000-0000-000000000000
On one of the another proxmox node (pve02b) I have configured a netdata agent (child) in /etc/netdata/stream.conf:
[stream]
enabled = yes
destination = tcp:tn-pve02.sub.domain.com
timeout seconds = 60
default port = 20489
send charts matching = *
buffer size bytes = 1048576
reconnect delay seconds = 5
However
on parent http://tn-pve02.sub.domain.com:20489
I only see node tn-pve02 (the parents own stats) but not pve02b (child stats)
on child as http://pve02b.sub.domain.com:19999
I can see the child stats only on pve02b (child)
systemctl status netdata gitves: “STREAM pve02b [send to tcp:tn-pve02.sub.domain.com]: remote server denied access, probably we don’t have the right API key? - will retry”
During testing, the API-key as shown was used.
What am I doing wrong here?
Best regards
Marco
Hi, @motto. It is hard to follow your configs because you didn’t use formatting, but your streaming configuration is wrong (API key placement). Consider checking Configure Parent/Child docs.
@ilyam8 it looks like I can not use the installation script as describe in Configure Parent/Child docs.
Autodetected containerized Netdata instance. Attempting to autodetect container ID.
ERROR: Unable to find a usable container tool stack. I support Docker and Podman.
Also, there is a port (20489) used for the parent-dashboard, that seems to be different from the 19999. 19999 seems to be closed on TrueNAS and there is probably a lot of Kubernetes involved to get it open (?) that I do not want to deal with.
I probably need to install a netdata instance somewhere outside TrueNAS for the parent, which makes it less suitable for my case. I will try other Truenas apps instead first and see if I find a solution within Truenas.
Best regards
PS: sorry for my bad styling of the code sample in my first post
