Statsd : smart naming of app counters for auto zc positive/negative parts?
Hi
When pushing e.g. counters to statsd, is there a zero-config way that netdata combines them into charts with positive/negative lines?
E.g. if i name 2 of my counters : myapp.mycounter.read, myapp.mycounter.write, can I expect netdata to chart them together into a single chart with positive/negative lines; similar with network or disk read/write charts in the standard system configs.
I understand from docs that I can configure this myself with 5-10 lines of config per chart (exposing dimensions specially named ‘read’ , ‘write’ or similar), but it would be really useful if there was a way to achieve this with zero-configuration, e.g. by how the coutners area named
Thanks!
Hi @Techno_Magos,
The StatsD collector is not currently able to do this. You can easily define a Synthetic Chart like the following:
[mychart]
    name = mychart
    title = my chart title
    family = my family
    context = chart.context
    units = tests/s
    priority = 91000
    type = area
    dimension = myapp.metric1 m1 last  1 1
    dimension = myapp.metric2 m2 last 1 -1
To do this, use the edit-config tool that you will find in the /etc/netdata directory, for example:
sudo edit-config statsd.d/myapp.conf .
