We have two mount points at /usr and /usr/sap that are not visible.
Both are lvm’s and in different volume groups.
The strange think is that their volume group are visible…
All other lvm mount points are visible.
I can see the plugins are loaded and checking the mount points in the netdata.conf.
[plugin:proc:diskspace:/usr]
# space usage = auto
# inodes usage = auto
[plugin:proc:diskspace:/usr/sap]
The vm is RedHat 8.2
The netdata version is the latest: v1.31.0-258-nightly
Please note that this is happening to all vm’s with the same mount points config.
What is causing this behavior?
Mount points to be visible
