web_log_1m_internal_errors
Web Server | Web log
Response status codes beginning with the digit “5” indicate cases in which the server is aware that it has erred or is incapable of performing the request. Except when responding to a HEAD request, the server should include an entity containing an explanation of the error situation, and whether it is a temporary or permanent condition. User agents should display any included entity to the user. These response codes are applicable to any request method.1
The Netdata Agent calculates the ratio of server error HTTP requests over the last minute.
Server error responses (5XX)
The error codes below contain the descriptions as provided by
Mozilla. 2
500 Internal Server Error: The server has encountered a situation it does not know how to
handle. -
501 Not Implemented: The request method is not supported by the server and cannot be handled.
The only methods that servers are required to support (and therefore that must not return this
code) are GET and HEAD. -
502 Bad Gateway: This error response means that the server, while working as a gateway to get a
response needed to handle the request, got an invalid response. -
503 Service Unavailable: The server is not ready to handle the request. Common causes are a
server that is down for maintenance or that is overloaded. Note that together with this response,
a user-friendly page explaining the problem should be sent. This response should be used for
temporary conditions and the Retry-After HTTP header should, if possible, contain the estimated
time before the recovery of the service. The webmaster must also take care about the
caching-related headers that are sent along with this response, as these temporary condition
responses should usually not be cached. -
504 Gateway Timeout: This error response is given when the server is acting as a gateway and
cannot get a response in time. -
505 HTTP Version Not Supported: The HTTP version used in the request is not supported by the
server. -
506 Variant Also Negotiates: The server has an internal configuration error: the chosen variant
resource is configured to engage in transparent content negotiation itself, and is therefore not a
proper end point in the negotiation process. -
507 Insufficient Storage (WebDAV):
The method could not be performed on the resource because the server is unable to store the
representation needed to successfully complete the request. -
508 Loop Detected (WebDAV):
The server detected an infinite loop while processing the request. -
510 Not Extended: Further extensions to the request are required for the server to fulfill it.
511 Network Authentication: Required Indicates that the client needs to authenticate to gain
network access.
Source: https://developer.mozilla.org/en-US/docs/Web/HTTP/Status#server_error_responses
References and sources
Troubleshooting section:
General approach
To identify the HTTP response code your web server sends back:
- Open the Netdata dashboard.
- Inspect the
detailed_response_codeschart for your web server. This chart keeps track of exactly what error codes your web server sends out.
You should also check the server error logs. For example, web servers such as Apache or Nginx produce and error logs, by default under /var/log/{nginx, apache2}/{access.log, error.log}
Troubleshoot 500 error code
One of the things that can cause HTTP 500 response errors is a misconfiguration in the .htaccess file of your web server.
