web_log_5m_requests_ratio
Web Server | Web log
The Netdata Agent calculates the ratio of successful HTTP requests over the last 5 minutes, compared with the previous 5 minutes. These requests consist of 1xx, 2xx, 304, 401 response codes.
There is a warning alert when the percentage of requests is increased more than 25% in the last 5 minutes compared with the previous 5 minutes and in critical when it increased more than 50%. A clear notification for this alert will not be sent when the ratio becomes normal again.
Troubleshooting section:
This alert is not always a bad thing. It means that there is a slight increase in the requests towards to your Web server. You should just keep an eye on this metrics. If you receive this alert regularly you should consider take action in advance to avoid server overload.
You can find an interesting article on actions you can take to manage sudden traffic on a web server (this article is produced by the NGINX associates, but nearly same principles applied in any case)
