I’m running Netdata in a docker container and let it update-check on a daily basis: docker pull netdata/netdata && docker stop netdata && docker rm netdata && docker run -d --name=netdata … This might have been happened shortly after I got the warning below…!?
Starting some days ago (Jan, 30th) I got this warning from one of my netdata-agents:
10min_cpu_iowait with 40.63 %
some minute later: a clear messages/info-mail 10min_cpu_iowait with 16.59 %
some hours later: another warning 10min_cpu_iowait with 40.54 %
As I can see in my “System Overview” iowait is not significantly high, so that I’m still missing the finale clear messages/info-mail.
Why does it not clear this warning? And/or how can I clear this manually?
In this case this is a “normal” Linux VM running a Netdata Agent in a Docker Container
Many thanks for this computational aid Just that I have understood it correctly:
The warning will only be cleared, if there had been or will be a period of at least 22 minutes and 30 seconds (15 mins x 1,5) without a high iowait-timeframe again (which is currently not the case - so everything seems to be fine with Netdata and I have now a better understanding).
