1min_netdev_backlog_exceeded
OS: Linux
The linux kernel contains queues where packets are stored after reception from a network interface controller before being processed by the next protocol stack. There is one netdev backlog queue per CPU core. netdev_max_backlog defines the maximum number of packets that can enter the queue. Queues fill up when an interface receives packets faster than kernel can process them. The default netdev_max_backlog value should be 1000. However this may not be enough in cases such as:
Multiple interfaces operating at 1Gbps, or even a single interface at 10Gbps.
Lower powered systems process very large amounts of network traffic.
Netdata agent monitors the average number of dropped packets in the last minute due to exceeding the netdev backlog queue.
Troubleshooting section:
Increase the netdev_max_backlog value
Check your current value:
root@netdata~ # sysctl net.core.netdev_max_backlog net.core.netdev_max_backlog = 1000 -
Try to increase it by a factor of 2.
root@netdata~ # sysctl -w net.core.netdev_max_backlog=2000 -
Verify the change and test with the same workload that triggered the alarm originally.
root@netdata~ # sysctl net.core.netdev_max_backlog net.core.netdev_max_backlog = 2000 -
If this change works for your system, you could make it permanently.
Bump this
net.core.netdev_max_backlog=2000entry under/etc/sysctl.conf. -
Reload the sysctl settings.
root@netdata~ # sysctl -p
