http://127.0.0.1/v3/api/v3/data?aggregation=average&after=1749700800&before=1749697200
I’m collecting data every 5 seconds.
But when I query it via the Netdata API, I see data points every second.
As far as I understand, this seems to be some kind of interpolation or adjustment for chart display.
Is there a way to disable this and get only the raw collected data?
I saw in the documentation that using options=natural-points might help,
so I tried it — but it doesn’t seem to work.
Am I missing something? Or is there another way to get only the raw data points as collected?
v2.2.0-139
