Is it possible to get raw data from our monitoring results?
You can export data from the Netdata API and use GET /datato get collected data for a specific chart. Here is where you can find the links to our complete API documentation.
You can also enable the exporting engine to send metrics to external time-series databases. Read more in our Exporting engine reference.
Haiii i’m from indonesia, i have question:)
How to download raw data with mongodb?
Hey @Raden_Ayu_Tamara_Sn, welcome to our Forums!
What is your exact need? Do you need to regularly send metrics to external time-series databases or this is a one-time export?
Can you take a look at the links I’ve posted above and let me know if that helps? In order to enable, configure and monitor Netdata’s exporting engine, you’ll have to work on the agent’s side.
I have installed libmongoc then reinstall netdata and netdata configuration.
What is the next stage so that I can get data with json format?please help me because I just used netdata
