Had an issue with my MacOS server and had to reinstall Netdata using the Brew install netdata command it it came back with no formulae or casks with that name…
Is Netdata no longer supported on MacOS via Brew?
Hello @JGamache - welcome!
Can you share some output or a screenshot with any more info?
@Austin_Hemmelgarn might know a bit more about installing on MacOS via Brew.
Sounds like the same issue discussed at https://www.reddit.com/r/netdata/comments/q1axf3/netdata_on_macos/.
In short:
Hi Austin,
Thank you very much for your reply…I finally had to nuke HomeBrew on my server and NetData and reinstall both from scratch and it seems to work now.
I wish I could get 1.31 but I am happy that I can get Netdata to work again.
Hey Andrew,
I basically deleted both Homebrew and Netdata completely and reinstalling seemed to solve the problems.
Jason
