Environment
CentOS 8 / Stream
# head -20 /etc/*release
==> /etc/centos-release <==
CentOS Linux release 8.3.2011
==> /etc/os-release <==
NAME="CentOS Linux"
VERSION="8"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="8"
PLATFORM_ID="platform:el8"
PRETTY_NAME="CentOS Linux 8"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:centos:centos:8"
HOME_URL="https://centos.org/"
BUG_REPORT_URL="https://bugs.centos.org/"
CENTOS_MANTISBT_PROJECT="CentOS-8"
CENTOS_MANTISBT_PROJECT_VERSION="8"
==> /etc/redhat-release <==
==> /etc/system-release <==
# uname -a
Linux test-vm 4.18.0-240.10.1.el8_3.x86_64 #1 SMP Mon Jan 18 17:05:51 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
As the title says, when configuring the Cloudpackage repository on CentOS 8 / Stream to install Netdata using dnf, the repository shows up as empty.
# cat /etc/yum.repos.d/netdata.repo
[netdata_netdata]
name=netdata_netdata
baseurl=https://packagecloud.io/netdata/netdata/el/8/$basearch
repo_gpgcheck=1
gpgcheck=0
enabled=1
gpgkey=https://packagecloud.io/netdata/netdata/gpgkey
sslverify=1
sslcacert=/etc/pki/tls/certs/ca-bundle.crt
metadata_expire=300
# dnf --disablerepo=* --enablerepo=netdata_netdata repolist -v
Loaded plugins: builddep, changelog, config-manager, copr, debug, debuginfo-install, download, generate_completion_cache, needs-restarting, playground, repoclosure, repodiff, repograph, repomanage, reposync
DNF version: 4.2.23
cachedir: /var/cache/dnf
Last metadata expiration check: 0:01:06 ago on Fri 12 Mar 2021 04:31:58 PM EET.
Repo-id : netdata_netdata
Repo-name : netdata_netdata
Repo-updated : Tue 22 Jan 2019 03:38:22 AM EET
Repo-pkgs : 0
Repo-available-pkgs: 0
Repo-size : 0
Repo-baseurl : https://packagecloud.io/netdata/netdata/el/8/x86_64
Repo-expire : 300 second(s) (last: Fri 12 Mar 2021 04:31:58 PM EET)
Repo-filename : /etc/yum.repos.d/netdata.repo
Total packages: 0
If I change the dnf configuration to el7 instead of el8, the el7 packages show up, but Netdata won’t install due to dependency errors. Using epel is not an option, because the Netdata version available there is too old (0.23 vs. 0.29).
I expect the el8 packages to be present in the el8 repository.
Would it be possible for you to push the el8 RPMs to Cloudpackage ?
Thanks!
