ceph_cluster_space_usage
Storage | Ceph
The Netdata Agent calculates the percentage of used cluster disk space. Your cluster is in high disk space utilization. To fix this issue, consider adding a node or removing unneeded data from the cluster.
This alert is triggered in warning state when the percentage of used cluster disk space is between 85-90% and in critical state when it is between 90-98%.
