Hello!
Sorry if this is a basic question, but I am trying to configure a local docker-run instance of netdata and I don’t seem to be able to get any configuration taken in account.
I am using a host-editable configuration. My compose file looks like this:
services:
netdata:
container_name: netdata
image: netdata/netdata:latest
restart: unless-stopped
pid: host
network_mode: host
cap_add:
- SYS_PTRACE
- SYS_ADMIN
security_opt:
- apparmor:unconfined
volumes:
- /home/docker/config/netdata:/etc/netdata
- /:/host/root:ro,rslave
- /etc/localtime:/etc/localtime:ro
- /proc:/host/proc:ro
- /sys:/host/sys:ro
- /var/log:/host/var/log:ro
- /var/run/docker.sock:/var/run/docker.sock:ro
- /run/dbus:/run/dbus:ro
I also have a pre-existing pg16 instance running on the same docker network.
I started with
mkdir /home/docker/config/netdata
docker compose up -d netdata
This adds plenty of files in the folder, I then go to edit /home/docker/config/netdata/go.d/postgres.confwith the content:
jobs:
- name: local
dsn: 'postgresql://netdata:abc123@127.0.0.1:5432/postgres'
I then run docker compose up -d --force-recreate netdata but it does not seem to take in account the postgres.conf file changes. It still uses the default connection info (i.e. with postgresas the password for the netdata user). This is the relevant docker log lines:
time=2025-07-01T19:58:37.777Z level=info msg="check success" plugin=go.d collector=postgres job=local
time=2025-07-01T19:58:37.778Z level=info msg="started, data collection interval 1s" plugin=go.d collector=postgres job=local
time=2025-07-01T19:58:41.413Z level=error msg="check failed: error on pinging the Postgres database [postgres://netdata:postgres@172.16.0.10:5432/postgres]: failed to connect to `host=172.16.0.10 user=netdata database=postgres`: failed SASL auth (FATAL: password authentication failed for user \"netdata\" (SQLSTATE 28P01))" plugin=go.d collector=postgres job=docker_postgres
The postgres logs also show the failed authentication attempt
2025-07-01 19:58:41.413 UTC [3811] FATAL: password authentication failed for user "netdata"
To me it looks like the /etc/netdata/go.d/postgres.conf file of the container is not read, and instead it is using the default values from /usr/lib/netdata/conf.d/go.d/postgres.conf
> docker exec -it netdata cat /usr/lib/netdata/conf.d/go.d/postgres.conf
## All available configuration options, their descriptions and default values:
## https://github.com/netdata/netdata/tree/master/src/go/plugin/go.d/collector/postgres#readme
#jobs:
# - name: local
# dsn: 'host=/var/run/postgresql dbname=postgres user=netdata'
# #collect_databases_matching: '*'
# - name: local
# dsn: 'postgresql://netdata@127.0.0.1:5432/postgres'
Other info
> docker exec -it netdata netdata -v
netdata v2.5.0-346-nightly
Honestly I think I’m not understanding something basic with how to configure the docker container, but I can’t figure it.
Full netdata.conf from the instance
Show
# netdata configuration
# You can download the latest version of this file, using:
# wget -O /etc/netdata/netdata.conf http://localhost:19999/netdata.conf
# or
# curl -o /etc/netdata/netdata.conf http://localhost:19999/netdata.conf
# You can uncomment and change any of the options below.
# The value shown in the commented settings, is the default value.
# global netdata configuration
# run as user = netdata
# host access prefix = /host
# pthread stack size = 8MiB
# cpu cores = 12
# libuv worker threads = 72
# profile = standalone
# hostname = <redacted>
# glibc malloc arena max for plugins = 1
# glibc malloc arena max for netdata = 1
# crash reports = all
# timezone = Etc/UTC
# OOM score = 0
# process scheduling policy = keep
# is ephemeral node = no
# has unstable connection = no
[db]
# enable replication = yes
# replication period = 1d
# replication step = 1h
# replication threads = 1
# replication prefetch = 36
# update every = 1s
# db = dbengine
# memory deduplication (ksm) = auto
# cleanup orphan hosts after = 1h
# cleanup ephemeral hosts after = off
# cleanup obsolete charts after = 1h
# dbengine page type = gorilla
# dbengine page cache size = 32MiB
# dbengine extent cache size = off
# dbengine enable journal integrity check = no
# dbengine use all ram for caches = no
# dbengine out of memory protection = 5GiB
# dbengine use direct io = yes
# dbengine journal v2 unmount time = 2m
# dbengine pages per extent = 109
# storage tiers = 3
# dbengine tier backfill = new
# dbengine tier 1 update every iterations = 60
# dbengine tier 2 update every iterations = 60
# dbengine tier 0 retention size = 1024MiB
# dbengine tier 0 retention time = 14d
# dbengine tier 1 retention size = 1024MiB
# dbengine tier 1 retention time = 3mo
# dbengine tier 2 retention size = 1024MiB
# dbengine tier 2 retention time = 2y
# extreme cardinality protection = yes
# extreme cardinality keep instances = 1000
# extreme cardinality min ephemerality = 50
[directories]
# config = /etc/netdata
# stock config = /usr/lib/netdata/conf.d
# log = /var/log/netdata
# web = /usr/share/netdata/web
# cache = /var/cache/netdata
# lib = /var/lib/netdata
# cloud.d = /var/lib/netdata/cloud.d
# plugins = "/usr/libexec/netdata/plugins.d" "/etc/netdata/custom-plugins.d"
# registry = /var/lib/netdata/registry
# home = /etc/netdata
# stock health config = /usr/lib/netdata/conf.d/health.d
# health config = /etc/netdata/health.d
[logs]
# facility = daemon
# logs flood protection period = 1m
# logs to trigger flood protection = 1000
# level = info
# debug = /var/log/netdata/debug.log
# daemon = /var/log/netdata/daemon.log
# collector = /var/log/netdata/collector.log
# access = /var/log/netdata/access.log
# health = /var/log/netdata/health.log
# debug flags = 0x0000000000000000
[environment variables]
# PATH = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/sbin
# PYTHONPATH =
# TZ = :/etc/localtime
[host labels]
# name = value
[cloud]
# conversation log = no
# scope = full
# query threads = 12
# proxy = env
[ml]
# enabled = auto
# maximum num samples to train = 21600
# minimum num samples to train = 900
# train every = 3h
# number of models per dimension = 18
# delete models older than = 7d
# num samples to diff = 1
# num samples to smooth = 3
# num samples to lag = 5
# random sampling ratio = 0.20000
# maximum number of k-means iterations = 1000
# dimension anomaly score threshold = 0.99000
# host anomaly rate threshold = 1.00000
# anomaly detection grouping method = average
# anomaly detection grouping duration = 5m
# num training threads = 1
# flush models batch size = 256
# dimension anomaly rate suppression window = 15m
# dimension anomaly rate suppression threshold = 450
# enable statistics charts = yes
# hosts to skip from training = !*
# charts to skip from training = netdata.*
# stream anomaly detection charts = yes
[health]
# silencers file = /var/lib/netdata/health.silencers.json
# enabled = yes
# enable stock health configuration = yes
# use summary for notifications = yes
# default repeat warning = off
# default repeat critical = off
# in memory max health log entries = 1000
# health log retention = 5d
# script to execute on alarm = /usr/libexec/netdata/plugins.d/alarm-notify.sh
# enabled alarms = *
# run at least every = 10s
# postpone alarms during hibernation for = 1m
[web]
#| >>> [web].default port <<<
#| migrated from: [global].default port
# default port = 19999
# ssl key = /etc/netdata/ssl/key.pem
# ssl certificate = /etc/netdata/ssl/cert.pem
# tls version = 1.3
# tls ciphers = none
# ses max tg_des_window = 15
# des max tg_des_window = 15
# mode = static-threaded
# listen backlog = 4096
# bind to = *
# bearer token protection = no
# disconnect idle clients after = 1m
# timeout for first request = 1m
# accept a streaming request every = off
# respect do not track policy = no
# x-frame-options response header =
# allow connections from = localhost *
# allow connections by dns = heuristic
# allow dashboard from = localhost *
# allow dashboard by dns = heuristic
# allow badges from = *
# allow badges by dns = heuristic
# allow streaming from = *
# allow streaming by dns = heuristic
# allow netdata.conf from = localhost fd* 10.* 192.168.* 172.16.* 172.17.* 172.18.* 172.19.* 172.20.* 172.21.* 172.22.* 172.23.* 172.24.* 172.25.* 172.26.* 172.27.* 172.28.* 172.29.* 172.30.* 172.31.* UNKNOWN
# allow netdata.conf by dns = no
# allow management from = localhost
# allow management by dns = heuristic
# enable gzip compression = yes
# gzip compression strategy = default
# gzip compression level = 3
# ssl skip certificate verification = no
# web server threads = 12
# web server max sockets = 262144
[registry]
# enabled = no
# registry db file = /var/lib/netdata/registry/registry.db
# registry log file = /var/lib/netdata/registry/registry-log.db
# registry save db every new entries = 1000000
# registry expire idle persons = 1y
# registry domain =
# registry to announce = https://registry.my-netdata.io
# registry hostname = <redacted>
# verify browser cookies support = yes
# enable cookies SameSite and Secure = yes
# max URL length = 1024
# max URL name length = 50
# netdata management api key file = /var/lib/netdata/netdata.api.key
# allow from = *
# allow by dns = heuristic
[pulse]
# extended = no
# update every = 1s
[plugins]
# idlejitter = yes
# netdata pulse = yes
# profile = no
# tc = yes
# diskspace = yes
# proc = yes
# cgroups = yes
# timex = yes
# enable running new plugins = yes
# check for new plugins every = 1m
# slabinfo = no
# freeipmi = no
# statsd = yes
# go.d = yes
# systemd-journal = yes
# apps = yes
# perf = yes
# debugfs = yes
# network-viewer = yes
# charts.d = yes
# python.d = yes
# systemd-units = yes
# ioping = yes
[statsd]
# update every (flushInterval) = 1s
# udp messages to process at once = 10
# create private charts for metrics matching = *
# max private charts hard limit = 1000
# set charts as obsolete after = off
# decimal detail = 1000
# disconnect idle tcp clients after = 10m
# private charts hidden = no
# histograms and timers percentile (percentThreshold) = 95.00000
# dictionaries max unique dimensions = 200
# add dimension for number of events received = no
# gaps on gauges (deleteGauges) = no
# gaps on counters (deleteCounters) = no
# gaps on meters (deleteMeters) = no
# gaps on sets (deleteSets) = no
# gaps on histograms (deleteHistograms) = no
# gaps on timers (deleteTimers) = no
# gaps on dictionaries (deleteDictionaries) = no
# statsd server max TCP sockets = 262144
# default port = 8125
# bind to = udp:localhost tcp:localhost
[plugin:idlejitter]
# loop time = 20ms
[plugin:go.d]
# update every = 1s
# command options =
[plugin:systemd-journal]
# update every = 1s
# command options =
[plugin:apps]
# update every = 1s
# command options =
[plugin:perf]
# update every = 1s
# command options =
[plugin:tc]
# script to run to get tc values = /usr/libexec/netdata/plugins.d/tc-qos-helper.sh
# enable tokens charts for all interfaces = no
# enable ctokens charts for all interfaces = no
# enable show all classes and qdiscs for all interfaces = no
# cleanup unused classes every = 120
[plugin:proc]
# /proc/net/dev = yes
# /proc/pagetypeinfo = no
# /proc/stat = yes
# /proc/uptime = yes
# /proc/loadavg = yes
# /proc/sys/fs/file-nr = yes
# /proc/sys/kernel/random/entropy_avail = yes
# /run/reboot_required = yes
# /proc/pressure = yes
# /proc/interrupts = yes
# /proc/softirqs = yes
# /proc/vmstat = yes
# /proc/meminfo = yes
# /sys/kernel/mm/ksm = yes
# /sys/block/zram = yes
# /sys/devices/system/edac/mc = yes
# /sys/devices/pci/aer = yes
# /sys/devices/system/node = yes
# /proc/net/wireless = yes
# /proc/net/sockstat = yes
# /proc/net/sockstat6 = yes
# /proc/net/netstat = yes
# /proc/net/sctp/snmp = yes
# /proc/net/softnet_stat = yes
# /proc/net/ip_vs/stats = yes
# /sys/class/infiniband = yes
# /proc/net/stat/conntrack = yes
# /proc/net/stat/synproxy = yes
# /proc/diskstats = yes
# /proc/mdstat = yes
# /proc/net/rpc/nfsd = yes
# /proc/net/rpc/nfs = yes
# /proc/spl/kstat/zfs/arcstats = yes
# /sys/fs/btrfs = yes
# ipc = yes
# /sys/class/power_supply = yes
# /sys/class/drm = yes
[plugin:proc:diskspace]
# remove charts of unmounted disks = yes
# update every = 1s
# check for new mount points every = 15s
# exclude space metrics on paths = /dev /dev/shm /proc/* /sys/* /var/run/user/* /run/lock /run/user/* /snap/* /var/lib/docker/* /var/lib/containers/storage/* /run/credentials/* /run/containerd/* /rpool /rpool/*
# exclude space metrics on filesystems = *gvfs *gluster* *s3fs *ipfs *davfs2 *httpfs *sshfs *gdfs *moosefs fusectl autofs cgroup cgroup2 hugetlbfs devtmpfs fuse.lxcfs
# exclude inode metrics on filesystems = msdosfs msdos vfat overlayfs aufs* *unionfs
# space usage for all disks = auto
# inodes usage for all disks = auto
[plugin:cgroups]
# update every = 1s
# check for new cgroups every = 10s
# use unified cgroups = auto
# max cgroups to allow = 1000
# max cgroups depth to monitor = 0
# enable by default cgroups matching = !*/init.scope !/system.slice/run-*.scope *user.slice/docker-* !*user.slice* *.scope !/machine.slice/*/.control !/machine.slice/*/payload* !/machine.slice/*/supervisor /machine.slice/*.service */kubepods/pod*/* */kubepods/*/pod*/* */*-kubepods-pod*/* */*-kubepods-*-pod*/* !*kubepods* !*kubelet* !*/vcpu* !*/emulator !*.mount !*.partition !*.service !*.service/udev !*.socket !*.slice !*.swap !*.user !/ !/docker !*/libvirt !/lxc !/lxc/*/* !/lxc.monitor* !/lxc.pivot !/lxc.payload !*lxcfs.service/.control !/machine !/qemu !/system !/systemd !/user *
# enable by default cgroups names matching = *
# search for cgroups in subpaths matching = !*/init.scope !*-qemu !*.libvirt-qemu !/init.scope !/system !/systemd !/user !/lxc/*/* !/lxc.monitor !/lxc.payload/*/* !/lxc.payload.* *
# script to get cgroup names = /usr/libexec/netdata/plugins.d/cgroup-name.sh
# script to get cgroup network interfaces = /usr/libexec/netdata/plugins.d/cgroup-network
# run script to rename cgroups matching = !/ !*.mount !*.socket !*.partition /machine.slice/*.service !*.service !*.slice !*.swap !*.user !init.scope !*.scope/vcpu* !*.scope/emulator *.scope *docker* *lxc* *qemu* */kubepods/pod*/* */kubepods/*/pod*/* */*-kubepods-pod*/* */*-kubepods-*-pod*/* !*kubepods* !*kubelet* *.libvirt-qemu *
# cgroups to match as systemd services = !/system.slice/*/*.service /system.slice/*.service
[plugin:timex]
# update every = 10s
# clock synchronization state = yes
# time offset = yes
[plugin:debugfs]
# update every = 1s
# command options =
[plugin:network-viewer]
# update every = 1s
# command options =
[plugin:charts.d]
# update every = 1s
# command options =
[plugin:python.d]
# update every = 1s
# command options =
[plugin:systemd-units]
# update every = 1s
# command options =
[plugin:ioping]
# update every = 1s
# command options =
[plugin:proc:/proc/net/dev]
# compressed packets for all interfaces = no
# disable by default interfaces matching = lo fireqos* *-ifb fwpr* fwbr* fwln* ifb4*
[plugin:proc:/proc/stat]
# cpu utilization = yes
# per cpu core utilization = no
# cpu interrupts = yes
# context switches = yes
# processes started = yes
# processes running = yes
# keep per core files open = yes
# keep cpuidle files open = yes
# core_throttle_count = auto
# package_throttle_count = no
# cpu frequency = yes
# cpu idle states = no
# core_throttle_count filename to monitor = /host/sys/devices/system/cpu/%s/thermal_throttle/core_throttle_count
# package_throttle_count filename to monitor = /host/sys/devices/system/cpu/%s/thermal_throttle/package_throttle_count
# scaling_cur_freq filename to monitor = /host/sys/devices/system/cpu/%s/cpufreq/scaling_cur_freq
# time_in_state filename to monitor = /host/sys/devices/system/cpu/%s/cpufreq/stats/time_in_state
# schedstat filename to monitor = /host/proc/schedstat
# cpuidle name filename to monitor = /host/sys/devices/system/cpu/cpu%zu/cpuidle/state%zu/name
# cpuidle time filename to monitor = /host/sys/devices/system/cpu/cpu%zu/cpuidle/state%zu/time
# filename to monitor = /host/proc/stat
[plugin:proc:/proc/uptime]
# filename to monitor = /host/proc/uptime
[plugin:proc:/proc/loadavg]
# filename to monitor = /host/proc/loadavg
# enable load average = yes
# enable total processes = yes
[plugin:proc:/proc/sys/fs/file-nr]
# filename to monitor = /host/proc/sys/fs/file-nr
[plugin:proc:/proc/sys/kernel/random/entropy_avail]
# filename to monitor = /host/proc/sys/kernel/random/entropy_avail
[plugin:proc:/proc/pressure]
# base path of pressure metrics = /proc/pressure
# enable cpu some pressure = yes
# enable cpu full pressure = no
# enable memory some pressure = yes
# enable memory full pressure = yes
# enable io some pressure = yes
# enable io full pressure = yes
# enable irq some pressure = no
# enable irq full pressure = yes
[plugin:proc:/proc/interrupts]
# interrupts per core = no
# filename to monitor = /host/proc/interrupts
[plugin:proc:/proc/softirqs]
# filename to monitor = /host/proc/softirqs
[plugin:proc:/proc/vmstat]
# filename to monitor = /host/proc/vmstat
# swap i/o = auto
# disk i/o = yes
# memory page faults = yes
# out of memory kills = yes
# system-wide numa metric summary = auto
# transparent huge pages = auto
# zswap i/o = auto
# memory ballooning = auto
# kernel same memory = auto
[plugin:proc:/sys/devices/system/node]
# directory to monitor = /host/sys/devices/system/node
# enable per-node numa metrics = auto
[plugin:proc:/proc/meminfo]
# system ram = yes
# system swap = auto
# hardware corrupted ECC = auto
# committed memory = yes
# writeback memory = yes
# kernel memory = yes
# slab memory = yes
# hugepages = auto
# transparent hugepages = auto
# memory reclaiming = yes
# high low memory = yes
# cma memory = auto
# direct maps = yes
# filename to monitor = /host/proc/meminfo
[plugin:proc:/sys/kernel/mm/ksm]
# /sys/kernel/mm/ksm/pages_shared = /host/sys/kernel/mm/ksm/pages_shared
# /sys/kernel/mm/ksm/pages_sharing = /host/sys/kernel/mm/ksm/pages_sharing
# /sys/kernel/mm/ksm/pages_unshared = /host/sys/kernel/mm/ksm/pages_unshared
# /sys/kernel/mm/ksm/pages_volatile = /host/sys/kernel/mm/ksm/pages_volatile
[plugin:proc:/sys/devices/system/edac/mc]
# directory to monitor = /host/sys/devices/system/edac/mc
[plugin:proc:/sys/class/pci/aer]
# enable root ports = yes
# enable pci slots = no
[plugin:proc:/sys/devices/pci/aer]
[plugin:proc:/proc/net/wireless]
# filename to monitor = /host/proc/net/wireless
# status for all interfaces = auto
# quality for all interfaces = auto
# discarded packets for all interfaces = auto
# missed beacon for all interface = auto
[plugin:proc:/proc/net/sockstat]
# ipv4 sockets = auto
# ipv4 TCP sockets = auto
# ipv4 TCP memory = auto
# ipv4 UDP sockets = auto
# ipv4 UDP memory = auto
# ipv4 UDPLITE sockets = auto
# ipv4 RAW sockets = auto
# ipv4 FRAG sockets = auto
# ipv4 FRAG memory = auto
# update constants every = 1m
# filename to monitor = /host/proc/net/sockstat
[plugin:proc:/proc/net/sockstat6]
# ipv6 TCP sockets = auto
# ipv6 UDP sockets = auto
# ipv6 UDPLITE sockets = auto
# ipv6 RAW sockets = auto
# ipv6 FRAG sockets = auto
# filename to monitor = /host/proc/net/sockstat6
[plugin:proc:/proc/net/netstat]
# bandwidth = auto
# input errors = auto
# multicast bandwidth = auto
# broadcast bandwidth = auto
# multicast packets = auto
# broadcast packets = auto
# ECN packets = auto
# TCP reorders = auto
# TCP SYN cookies = auto
# TCP out-of-order queue = auto
# TCP connection aborts = auto
# TCP memory pressures = auto
# TCP SYN queue = auto
# TCP accept queue = auto
# filename to monitor = /host/proc/net/netstat
[plugin:proc:/proc/net/snmp]
# ipv4 packets = auto
# ipv4 fragments sent = auto
# ipv4 fragments assembly = auto
# ipv4 errors = auto
# ipv4 TCP connections = auto
# ipv4 TCP packets = auto
# ipv4 TCP errors = auto
# ipv4 TCP opens = auto
# ipv4 TCP handshake issues = auto
# ipv4 UDP packets = auto
# ipv4 UDP errors = auto
# ipv4 ICMP packets = auto
# ipv4 ICMP messages = auto
# ipv4 UDPLite packets = auto
# filename to monitor = /host/proc/net/snmp
[plugin:proc:/proc/net/snmp6]
# ipv6 packets = auto
# ipv6 fragments sent = auto
# ipv6 fragments assembly = auto
# ipv6 errors = auto
# ipv6 UDP packets = auto
# ipv6 UDP errors = auto
# ipv6 UDPlite packets = auto
# ipv6 UDPlite errors = auto
# bandwidth = auto
# icmp = auto
# icmp redirects = auto
# icmp errors = auto
# icmp echos = auto
# icmp group membership = auto
# icmp router = auto
# icmp neighbor = auto
# icmp mldv2 = auto
# icmp types = auto
# ect = auto
# filename to monitor = /host/proc/net/snmp6
[plugin:proc:/proc/net/sctp/snmp]
# established associations = auto
# association transitions = auto
# fragmentation = auto
# packets = auto
# packet errors = auto
# chunk types = auto
# filename to monitor = /host/proc/net/sctp/snmp
[plugin:proc:/proc/net/softnet_stat]
# softnet_stat per core = no
# filename to monitor = /host/proc/net/softnet_stat
[plugin:proc:/proc/net/ip_vs_stats]
# IPVS bandwidth = yes
# IPVS connections = yes
# IPVS packets = yes
# filename to monitor = /host/proc/net/ip_vs_stats
[plugin:proc:/sys/class/infiniband]
# dirname to monitor = /host/sys/class/infiniband
# bandwidth counters = yes
# packets counters = yes
# errors counters = yes
# hardware packets counters = auto
# hardware errors counters = auto
# monitor only active ports = auto
# refresh ports state every = 30s
[plugin:proc:/proc/net/stat/nf_conntrack]
# filename to monitor = /host/proc/net/stat/nf_conntrack
# netfilter new connections = no
# netfilter connection changes = no
# netfilter connection expectations = no
# netfilter connection searches = no
# netfilter errors = no
# netfilter connections = yes
[plugin:proc:/proc/sys/net/netfilter/nf_conntrack_max]
# filename to monitor = /host/proc/sys/net/netfilter/nf_conntrack_max
# read every seconds = 10
[plugin:proc:/proc/sys/net/netfilter/nf_conntrack_count]
# filename to monitor = /host/proc/sys/net/netfilter/nf_conntrack_count
[plugin:proc:/proc/net/stat/synproxy]
# SYNPROXY cookies = auto
# SYNPROXY SYN received = auto
# SYNPROXY connections reopened = auto
# filename to monitor = /host/proc/net/stat/synproxy
[plugin:proc:/proc/diskstats]
# enable new disks detected at runtime = yes
# performance metrics for physical disks = auto
# performance metrics for virtual disks = auto
# performance metrics for partitions = no
# bandwidth for all disks = auto
# operations for all disks = auto
# merged operations for all disks = auto
# i/o time for all disks = auto
# queued operations for all disks = auto
# utilization percentage for all disks = auto
# extended operations for all disks = auto
# backlog for all disks = auto
# bcache for all disks = auto
# bcache priority stats update every = off
# remove charts of removed disks = yes
# path to get block device = /host/sys/block/%s
# path to get block device bcache = /host/sys/block/%s/bcache
# path to get virtual block device = /host/sys/devices/virtual/block/%s
# path to get block device infos = /host/sys/dev/block/%lu:%lu/%s
# path to device mapper = /host/dev/mapper
# path to /dev/disk = /host/dev/disk
# path to /sys/block = /host/sys/block
# path to /dev/disk/by-label = /host/dev/disk/by-label
# path to /dev/disk/by-id = /host/dev/disk/by-id
# path to /dev/vx/dsk = /host/dev/vx/dsk
# name disks by id = no
# preferred disk ids = *
# exclude disks = loop* ram*
# filename to monitor = /host/proc/diskstats
# performance metrics for disks with major 259 = yes
# performance metrics for disks with major 252 = yes
[plugin:proc:/proc/mdstat]
# faulty devices = yes
# nonredundant arrays availability = yes
# mismatch count = auto
# disk stats = yes
# operation status = yes
# make charts obsolete = yes
# filename to monitor = /host/proc/mdstat
# mismatch_cnt filename to monitor = /host/sys/block/%s/md/mismatch_cnt
[plugin:proc:/proc/net/rpc/nfsd]
# filename to monitor = /host/proc/net/rpc/nfsd
[plugin:proc:/proc/net/rpc/nfs]
# network = yes
# rpc = yes
# NFS v2 procedures = yes
# NFS v3 procedures = yes
# NFS v4 procedures = yes
[plugin:proc:/proc/spl/kstat/zfs/arcstats]
# filename to monitor = /host/proc/spl/kstat/zfs/arcstats
[plugin:proc:/sys/fs/btrfs]
# path to monitor = /host/sys/fs/btrfs
# check for btrfs changes every = 1m
# physical disks allocation = auto
# data allocation = auto
# metadata allocation = auto
# system allocation = auto
# commit stats = auto
# error stats = auto
[plugin:proc:ipc]
# message queues = yes
# semaphore totals = yes
# shared memory totals = yes
# msg filename to monitor = /host/proc/sysvipc/msg
# shm filename to monitor = /host/proc/sysvipc/shm
# max dimensions in memory allowed = 50
[plugin:proc:/sys/class/power_supply]
# battery capacity = yes
# battery power = yes
# battery charge = no
# battery energy = no
# power supply voltage = no
# keep files open = auto
# directory to monitor = /host/sys/class/power_supply
[plugin:proc:/sys/class/drm]
# directory to monitor = /host/sys/class/drm
