Just a quick one: I’ve setup the DNS latency collector as per:
The chart for latency looks OK but the one for query status shows all as returning a value of ‘0’. This seems count-intuitive to me; is there any good reason why it’s a 0 instead of a 1? ![]()
Hi, @Luis_Johnstone. The query_status chart has 3 dimensions: success, network_error, dns_error.
Ah, I see; it’s because you need any of the other 3 dimensions of the chart to also be able to be a 1 to indicate a problem (e.g. it wouldn’t make sense if network_error = 1 meant everything was OK). I figured that it was something like that. Thanks!!
It is like this @Luis_Johnstonebecause because aggregation over time is meaningful.
For instance, you get an average value for every state for the last 30 minutes and they are:
This means that in the last 30 minutes, the percentage of successful requests is 70%, and so on.
