Environment
Running netdata/netdata:v1.29.3 docker image on top of aarch64 architecture
This is the snmp.conf I use for collecting my router BW info (faked some data for security reasons):
"enable_autodetect": false,
"update_every": 5,
"max_request_size": 100,
"servers": [
"hostname": "192.161.1.1",
"community": "my_comunity",
"update_every": 10,
"max_request_size": 50,
"options": {
"timeout": 10000
"charts": {
"snmp.lte1_tx_rx_rate": {
"title": "SNMP Bandwidth for lte1",
"units": "kilobits/s",
"type": "area",
"priority": 1,
"family": "mikrotik",
"dimensions": {
"in": {
"oid": "1.3.6.1.2.1.31.1.1.1.6.5",
"algorithm": "incremental",
"multiplier": 8,
"divisor": 1024,
"offset": 0
"out": {
"oid": "1.3.6.1.2.1.31.1.1.1.10.5",
"multiplier": -8,
"divisor": 1024,
"offset": 0
Inspired by: https://www.who-els.co.za/2019/06/netdata-snmp-mikrotik.html
Let x = average rate from the last day
bw = total bw over a month assuming daily rate is x (and it doesn’t change)
if bw > 50 GB: warn
if bw > 70 GB: critical
as for the calculation of x, I encountered some issues and had to split it to two calculations, also I configured the calculation to run every 12 hours. See following config, which is my best attempt defining the alarm:
alarm : monthly_bandwidth_rate_in
on: snmp.lte1_tx_rx_rate
lookup: average -1d every 10s unaligned absolute of in
info: monthly BW average kilobits/s of in
to: sysadmin
alarm : monthly_bandwidth_rate_out
lookup: average -1d every 10s unaligned absolute of out
info: monthly BW average kilobits/s of out
to: sysadmin
every: 12h
calc: ($monthly_bandwidth_rate_out + $monthly_bandwidth_rate_in) * 60 * 60 * 24 * 30 / 8 / 1024 / 1024
units: Gbyte
warn: $this > 50
crit: $this > 70
info: monthly BW average GB/month
to: sysadmin
alarm : monthly_bandwidth_fake1
every: 12h
warn: $this > 50
crit: $this > 70
to: sysadmin
alarm : monthly_bandwidth_fake2
every: 12h
calc: ($monthly_bandwidth_rate_out)
warn: $this > 50
crit: $this > 70
to: sysadmin
There are two issues with that resault:
monthly_bandwidthunits arekilobits/sand I wasn’t able to change them to anything else -
The avg calculated is wrong since running the following
curl 'http://10.9.0.6:19999/api/v1/data?chart=snmp.lte1_tx_rx_rate&points=1&&group=average&after=-86400d&before=0' --compressed --insecure
"labels": ["time", "in", "out"],
"data":
[ 1616371200, 11.4808157, -2.3677532]
resulted in different average values:
11.4808157 and abs(-2.3677532) using api
vs
1.08 and 0.77 in my defined alarms
I am not sure how to proceed and debug this issues .
Any help would be appreciated
