Hello @Stelios_Fragkakis
Thansk for your answer. I’m using RPM package for the installation and 1.38 is the latest version available.
https://repo.netdata.cloud/repos/stable/ubuntu/bionic/
The error is on almost all children I would say, the alarm is sent by the parent.
The config on the children is the following:
hostname = RABBIT-MEMCACHE-PROD
enabled = yes
[web]
bind to = *
web files owner = root
web files group = netdata
Version on the children is
root@test:~# netdata -v
netdata v1.37.0-17-nightly
Error log on the last impacted server:
2023-07-14 03:58:42: tc-qos-helper.sh: WARNING: FireQOS is not installed on this system. Use FireQOS to apply traffic QoS and expose the class names to netdata. Check https://github.com/netdata/netdata/tree/master/collectors/tc.plugin#tcplugin
2023-07-14 03:58:42: tc-qos-helper.sh: WARNING: Cannot find file '/usr/lib/netdata/conf.d/tc-qos-helper.conf'.
2023-07-14 03:58:42: tc-qos-helper.sh: WARNING: Cannot find file '/etc/netdata/tc-qos-helper.conf'.
2023-07-14 04:14:44: netdata INFO : MAIN : Creating new data and journal files in path /var/cache/netdata/dbengine
2023-07-14 04:14:44: netdata INFO : MAIN : Created data file "/var/cache/netdata/dbengine/datafile-1-0000005933.ndf".
2023-07-14 04:14:44: netdata INFO : MAIN : Created journal file "/var/cache/netdata/dbengine/journalfile-1-0000005933.njf".
2023-07-14 04:31:49: netdata INFO : MAIN : Deleting data file "/var/cache/netdata/dbengine/datafile-1-0000005915.ndf".
2023-07-14 04:31:49: netdata INFO : MAIN : Deleting data and journal file pair.
2023-07-14 04:31:49: netdata INFO : MAIN : Deleted journal file "/var/cache/netdata/dbengine/journalfile-1-0000005915.njf".
2023-07-14 04:31:49: netdata INFO : MAIN : Deleted data file "/var/cache/netdata/dbengine/datafile-1-0000005915.ndf".
2023-07-14 04:31:49: netdata INFO : MAIN : Reclaimed 14729216 bytes of disk space.
2023-07-14 04:35:30: netdata INFO : MAIN : METADATA: Checking dimensions starting after row 0
2023-07-14 04:35:30: netdata INFO : MAIN : METADATA: Checked 3464, deleted 0 -- will resume after row 0 in 3600 seconds
2023-07-14 04:58:44: tc-qos-helper.sh: WARNING: FireQOS is not installed on this system. Use FireQOS to apply traffic QoS and expose the class names to netdata. Check https://github.com/netdata/netdata/tree/master/collectors/tc.plugin#tcplugin
2023-07-14 04:58:44: tc-qos-helper.sh: WARNING: Cannot find file '/usr/lib/netdata/conf.d/tc-qos-helper.conf'.
2023-07-14 04:58:44: tc-qos-helper.sh: WARNING: Cannot find file '/etc/netdata/tc-qos-helper.conf'.
2023-07-14 05:11:42: netdata INFO : ANALYTICS : /usr/libexec/netdata/plugins.d/anonymous-statistics.sh 'META' '-' '-'
2023-07-14 05:35:31: netdata INFO : MAIN : METADATA: Checking dimensions starting after row 0
2023-07-14 05:35:31: netdata INFO : MAIN : METADATA: Checked 3464, deleted 0 -- will resume after row 0 in 3600 seconds
2023-07-14 05:57:14: netdata INFO : MAIN : Creating new data and journal files in path /var/cache/netdata/dbengine
2023-07-14 05:57:14: netdata INFO : MAIN : Created data file "/var/cache/netdata/dbengine/datafile-1-0000005934.ndf".
2023-07-14 05:57:14: netdata INFO : MAIN : Created journal file "/var/cache/netdata/dbengine/journalfile-1-0000005934.njf".
About the type of storage, I’m not sure what you mean, maybe
root@ns3131326:/var/log/netdata# fdisk -k
fdisk: invalid option -- 'k'
Try 'fdisk --help' for more information.
root@ns3131326:/var/log/netdata# fdisk -l
Disk /dev/nvme0n1: 419.2 GiB, 450098159616 bytes, 879097968 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 52D39457-95A3-49AF-B66F-EEE7E5413E1E
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1048575 1046528 511M EFI System
/dev/nvme0n1p2 1048576 2095103 1046528 511M Linux RAID
/dev/nvme0n1p3 2095104 43053055 40957952 19.5G Linux RAID
/dev/nvme0n1p4 43053056 878036991 834983936 398.2G Linux RAID
/dev/nvme0n1p5 878036992 879083519 1046528 511M Linux swap
Disk /dev/nvme1n1: 419.2 GiB, 450098159616 bytes, 879097968 sectors
Disklabel type: gpt
Disk identifier: E6F13B79-A2CC-42E2-A705-1F531DAB9A5B
/dev/nvme1n1p1 2048 1048575 1046528 511M EFI System
/dev/nvme1n1p2 1048576 2095103 1046528 511M Linux RAID
/dev/nvme1n1p3 2095104 43053055 40957952 19.5G Linux RAID
/dev/nvme1n1p4 43053056 878036991 834983936 398.2G Linux RAID
/dev/nvme1n1p5 878036992 879083519 1046528 511M Linux swap
Disk /dev/md2: 511 MiB, 535756800 bytes, 1046400 sectors
Disk /dev/md3: 19.5 GiB, 20970405888 bytes, 40957824 sectors
Disk /dev/md4: 398.2 GiB, 427511709696 bytes, 834983808 sectors
Another information is, if I delete (which I just did) the folder /home/netdata which contains:
The alarm then stops, but will start again in a couple of weeks.
Best regards
Emmanuel
