How to upgrade the Netdata Repos on ProxMox
Hi there,
I just noticed that my Proxmox shows a warning because the Netdata repos are for Bookworm, while my ProxMox was upgraded to Trixie a long time ago. Can someone please point me to the exact process to update the repos correctly? I don’t want a wrong repo introducing incorrect packages into the system.
Thanks.
Solution: get rid of Netdata and use something with actual support.
Or you can try asking Nedi Learn Netdata
