Impossible to set GPU Alerts
Hey All!
I’ve been wrestling with this for about 6 hours now and still can’t get this GPU alert to work. I’m starting to think it might actually be impossible! ^^
  • Using netdata v2.8.4, agent only, Ubuntu
  • Having Nvidia GPU and using nvidia_smi collector. All charts are working correctly under Metrics
  • Created gpu.conf under /etc/netdata/health.d with nvidia_smi.gpu_utilization as this was on the usage chart:
    alarm: gpu_usage
       on: nvidia_smi.gpu_utilization
    lookup: average -1m
    units: %
    every: 1m
     warn: $this > 80
     crit: $this > 90
     info: GPU usage monitoring
  • Above and dozens of configurations did not work. Alert is not showing in web and /api/v1/alarms?all
  • No relevant info in Journal and error.log
  • To narrow the problem, in above conf I only changed *on: system.ram*and alert appeared successfully. So I guess that must be a bigger problem with nvidia_smi?
Please help, I’m sooo stuck with this :frowning:
Hey, @JanItor. Use template instead of alarm.
template: gpu_usage
  lookup: average -1m
   units: %
   every: 1m
    warn: $this > 80
    crit: $this > 90
    info: High GPU usage ${label:product_name}
Of course! So obvious yet so tedious…
Thank You!
