I installed netdata on my zero via the kickstart script
wget -O /tmp/netdata-kickstart.sh https://get.netdata.cloud/kickstart.sh && sh /tmp/netdata-kickstart.sh
When the command finishes I can not access the dashboard on my pi zero.
I tried checking the logs under
/opt/netdata/var/log/netdata
but they are all empty.
also checking systemctl :
systemctl status netdata
but this only gives me this information:
Active: activating (auto-restart) (Result: signal) since Sun 2024-03-03 17:49:30 CET; 20s ago
Process: 1416 ExecStartPre=/bin/mkdir -p /opt/netdata/var/cache/netdata (code=exited, status=0/SUCCESS)
Process: 1418 ExecStartPre=/bin/chown -R netdata /opt/netdata/var/cache/netdata (code=exited, status=0/SUCCESS)
Process: 1419 ExecStartPre=/bin/mkdir -p /run/netdata (code=exited, status=0/SUCCESS)
Process: 1420 ExecStartPre=/bin/chown -R netdata /run/netdata (code=exited, status=0/SUCCESS)
Process: 1421 ExecStart=/opt/netdata/usr/sbin/netdata -P /run/netdata/netdata.pid -D (code=killed, signal=ILL)
Main PID: 1421 (code=killed, signal=ILL)
CPU: 848ms
I see that the last one gets killed but I do not know why.
Accessing the ip address only navigates me to a nginx welcome page.
The image I installed on my sd card is the minimal one recommended by the raspberry pi imager tool for the zero w 1(again the headless variant)
I expected to be able to start configuring the netdata settings after the script finished and I navigated to the 19999 endpoint.
I want to monitor the internet connection and ping some servers (not in my local network) trying to understand some outtage problems/spikes during some work which are happening and resulting in high lag. Also the dashboard from netdata would be helpfull since it is not only for me and having something visual would be very nice. Also I would love to use the pi zero w1 since it does not get affected by the main system, and it is also connected via ethernet
I appreciate your help.
here the console log from the kickstart script (re -run)
@pizero:/opt/netdata/var/log/netdata $ wget -O /tmp/netdata-kickstart.sh https://get.netdata.cloud/kickstart.sh && sh /tmp/netdata-kickstart.sh
--2024-03-03 18:10:50-- https://get.netdata.cloud/kickstart.sh
Resolving get.netdata.cloud (get.netdata.cloud)... 2606:4700:20::ac43:48aa, 2606:4700:20::681a:88d, 2606:4700:20::681a:98d, ...
Connecting to get.netdata.cloud (get.netdata.cloud)|2606:4700:20::ac43:48aa|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 88230 (86K) [application/octet-stream]
Saving to: ‘/tmp/netdata-kickstart.sh’
/tmp/netdata-kickstart.sh 100%[====================================================================================================================================>] 86.16K --.-KB/s in 0.05s
2024-03-03 18:10:52 (1.85 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [88230/88230]
--- Using /tmp/netdata-kickstart-PLT8W4Bpty as a temporary directory. ---
--- Checking for existing installations of Netdata... ---
--- Found an existing netdata install at /opt/netdata, with installation type 'kickstart-static'. ---
Root privileges required to run test -x /opt/netdata/usr/libexec/netdata/netdata-updater.sh
[/tmp/netdata-kickstart-PLT8W4Bpty]$ sudo test -x /opt/netdata/usr/libexec/netdata/netdata-updater.sh
OK
[/tmp/netdata-kickstart-PLT8W4Bpty]$ sudo /opt/netdata/usr/libexec/netdata/netdata-updater.sh --interactive --not-running-from-cron
Sun 3 Mar 18:10:53 CET 2024 : INFO: netdata-updater.sh: Checking if a newer version of the updater script is available.
Sun 3 Mar 18:10:55 CET 2024 : INFO: netdata-updater.sh: Entering /tmp/netdata-updater-4KM2TcLot4
Sun 3 Mar 18:10:55 CET 2024 : INFO: netdata-updater.sh: Current Version: 00104400000442
Sun 3 Mar 18:10:55 CET 2024 : INFO: netdata-updater.sh: Latest Version: 00104400000442
Sun 3 Mar 18:10:55 CET 2024 : INFO: netdata-updater.sh: Newest version (current=00104400000442 >= latest=00104400000442) is already installed
Sun 3 Mar 18:10:55 CET 2024 : INFO: netdata-updater.sh: Switching back to /tmp/netdata-kickstart-PLT8W4Bpty
OK
--- Updated existing install at /opt/netdata ---
--- Successfully updated existing netdata install at /opt/netdata. ---
--- Not attempting to claim existing install at /opt/netdata (no claiming token provided). ---
To view your system's real-time performance metrics, open your web browser and enter http://NODE:19999.
Replace NODE with the IP address or hostname of your Netdata server to access the dashboard.
Official documentation can be found online at https://learn.netdata.cloud/docs/.
Looking to monitor all of your infrastructure with Netdata? Check out Netdata Cloud at https://app.netdata.cloud.
Join our community and connect with us on:
- GitHub: https://github.com/netdata/netdata/discussions
- Discord: https://discord.gg/5ygS846fR6
- Our community forums: https://community.netdata.cloud/
Root privileges required to run rm -rf /tmp/netdata-kickstart-PLT8W4Bpty
[/home/usr]$ sudo rm -rf /tmp/netdata-kickstart-PLT8W4Bpty
OK
and here the original log:
--2024-03-03 17:17:51-- https://get.netdata.cloud/kickstart.sh
Resolving get.netdata.cloud (get.netdata.cloud)... 2606:4700:20::681a:88d, 2606:4700:20::ac43:48aa, 2606:4700:20::681a:98d, ...
Connecting to get.netdata.cloud (get.netdata.cloud)|2606:4700:20::681a:88d|:443... connected.
/tmp/netdata-kickst 100%[===================>] 86.16K --.-KB/s in 0.04s
2024-03-03 17:17:52 (1.90 MB/s) - ‘/tmp/netdata-kickstart.sh’ saved [88230/88230]
--- Using /tmp/netdata-kickstart-U2S5RwH98G as a temporary directory. ---
--- No existing installations of netdata found, assuming this is a fresh install. ---
WARNING Unable to determine Linux distribution for native packages.
WARNING Could not install native binary packages, falling back to alternative installation method.
[/tmp/netdata-kickstart-U2S5RwH98G]$ sh -c /usr/bin/curl https://github.com/netdata/netdata-nightlies/releases/latest -s -L -I -o /dev/null -w '%{url_effective}' | grep -Eo '[^/]+$'
OK
--- Attempting to install using static build... ---
[/tmp/netdata-kickstart-U2S5RwH98G]$ /usr/bin/curl --fail -q -sSL --connect-timeout 10 --retry 3 --output /tmp/netdata-kickstart-U2S5RwH98G/netdata-armv6l-latest.gz.run https://github.com/netdata/netdata-nightlies/releases/download/v1.44.0-442-nightly/netdata-armv6l-latest.gz.run
OK
[/tmp/netdata-kickstart-U2S5RwH98G]$ /usr/bin/curl --fail -q -sSL --connect-timeout 10 --retry 3 --output /tmp/netdata-kickstart-U2S5RwH98G/sha256sum.txt https://github.com/netdata/netdata-nightlies/releases/download/v1.44.0-442-nightly/sha256sums.txt
OK
--- Installing netdata ---
Root privileges required to run sh /tmp/netdata-kickstart-U2S5RwH98G/netdata-armv6l-latest.gz.run --
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo sh /tmp/netdata-kickstart-U2S5RwH98G/netdata-armv6l-latest.gz.run --
|.-. .-. .-. .-. . netdata
| '-' '-' '-' '-' real-time performance monitoring, done right!
(C) Copyright 2017-2023, Costa Tsaousis
All rights reserved
Released under GPL v3+
You are about to install netdata to this system.
netdata will be installed at:
/opt/netdata
The following changes will be made to your system:
# USERS / GROUPS
User 'netdata' and group 'netdata' will be added, if not present.
# LOGROTATE
This file will be installed if logrotate is present.
- /etc/logrotate.d/netdata
# SYSTEM INIT
If a supported init system is detected, appropriate configuration will be
installed to allow Netdata to run as a system service. We currently support
systemd, OpenRC, LSB init scripts, and traditional init.d setups, as well as
having experimental support for runit.
This package can also update a netdata installation that has been
created with another version of it.
Your netdata configuration will be retained.
After installation, netdata will be (re-)started.
netdata re-distributes a lot of open source software components.
Check its full license at:
...skipping 1 line
Please type y to accept, n otherwise: ^[[B^[[By
Please type y to accept, n otherwise: y
Creating directory /opt/netdata
Verifying archive integrity... 100% MD5 checksums are OK. All good.
Uncompressing netdata, the real-time performance and health monitoring system 100%
--- Attempt to create user/group netdata/netadata ---
Adding netdata user group ...
[/opt/netdata]# groupadd -r netdata
OK ''
Adding netdata user account with home /opt/netdata ...
[/opt/netdata]# useradd -r -g netdata -c netdata -s /usr/sbin/nologin --no-create-home -d /opt/netdata netdata
OK ''
--- Add user netdata to required user groups ---
Adding netdata user to the docker group ...
[/opt/netdata]# usermod -a -G docker netdata
OK ''
Group 'nginx' does not exist.
Group 'varnish' does not exist.
Group 'haproxy' does not exist.
Adding netdata user to the adm group ...
[/opt/netdata]# usermod -a -G adm netdata
OK ''
Group 'nsd' does not exist.
Adding netdata user to the proxy group ...
[/opt/netdata]# usermod -a -G proxy netdata
OK ''
Group 'squid' does not exist.
Group 'ceph' does not exist.
Group 'nobody' does not exist.
Group 'I2C' does not exist.
--- Install logrotate configuration for netdata ---
[/opt/netdata]# cp /opt/netdata/usr/lib/netdata/system/logrotate/netdata /etc/logrotate.d/netdata
OK ''
[/opt/netdata]# chmod 644 /etc/logrotate.d/netdata
OK ''
--- Telemetry configuration ---
You can opt out from anonymous statistics via the --disable-telemetry option, or by creating an empty file /opt/netdata/etc/netdata/.opt-out-from-anonymous-statistics
--- Install netdata at system init ---
Installing systemd service...
Created symlink /etc/systemd/system/multi-user.target.wants/netdata.service -> /lib/systemd/system/netdata.service.
--- Install (but not enable) netdata updater tool ---
Update script is located at /opt/netdata/usr/libexec/netdata/netdata-updater.sh
--- creating quick links ---
[/opt/netdata]# ln -s bin sbin
OK ''
[/opt/netdata/usr]# ln -s ../bin bin
OK ''
[/opt/netdata/usr]# ln -s ../bin sbin
OK ''
[/opt/netdata/usr]# ln -s . local
OK ''
[/opt/netdata]# ln -s etc/netdata netdata-configs
OK ''
[/opt/netdata]# ln -s usr/share/netdata/web netdata-web-files
OK ''
[/opt/netdata]# ln -s usr/libexec/netdata netdata-plugins
OK ''
[/opt/netdata]# ln -s var/lib/netdata netdata-dbs
OK ''
[/opt/netdata]# ln -s var/cache/netdata netdata-metrics
OK ''
[/opt/netdata]# ln -s var/log/netdata netdata-logs
OK ''
[/opt/netdata/etc/netdata]# rm orig
OK ''
[/opt/netdata/etc/netdata]# ln -s ../../usr/lib/netdata/conf.d orig
OK ''
--- fix permissions ---
[/opt/netdata]# chmod g+rx,o+rx /opt
OK ''
[/opt/netdata]# find /opt/netdata -type d -exec chmod go+rx {} +
OK ''
[/opt/netdata]# chown -R netdata:netdata /opt/netdata/var
OK ''
--- changing plugins ownership and permissions ---
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/ndsudo
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/apps.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/perf.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/slabinfo.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/debugfs.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/ioping
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/cgroup-network
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/local-listeners
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/network-viewer.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/ebpf.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/nfacct.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/python.d.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/charts.d.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/go.d.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/ioping.plugin
OK ''
[/opt/netdata]# chown root:netdata usr/libexec/netdata/plugins.d/cgroup-network-helper.sh
OK ''
[/opt/netdata]# setcap cap_dac_read_search,cap_sys_ptrace=ep usr/libexec/netdata/plugins.d/apps.plugin
OK ''
[/opt/netdata]# setcap cap_dac_read_search=ep usr/libexec/netdata/plugins.d/slabinfo.plugin
OK ''
[/opt/netdata]# setcap cap_dac_read_search=ep usr/libexec/netdata/plugins.d/debugfs.plugin
OK ''
[/opt/netdata]# setcap cap_perfmon=ep usr/libexec/netdata/plugins.d/perf.plugin
OK ''
[/opt/netdata]# setcap cap_dac_read_search+epi cap_net_admin+epi cap_net_raw=eip usr/libexec/netdata/plugins.d/go.d.plugin
OK ''
[/opt/netdata]# chmod 4750 usr/libexec/netdata/plugins.d/ioping
OK ''
[/opt/netdata]# chmod 4750 usr/libexec/netdata/plugins.d/cgroup-network
OK ''
[/opt/netdata]# chmod 4750 usr/libexec/netdata/plugins.d/local-listeners
OK ''
[/opt/netdata]# chmod 4750 usr/libexec/netdata/plugins.d/network-viewer.plugin
OK ''
[/opt/netdata]# chmod 4750 usr/libexec/netdata/plugins.d/ebpf.plugin
OK ''
[/opt/netdata]# chmod 4750 usr/libexec/netdata/plugins.d/nfacct.plugin
OK ''
Configure TLS certificate paths
Using /etc/ssl for TLS configuration and certificates
Save install options
--- starting netdata ---
--- Restarting netdata instance ---
Stopping all netdata threads
[/opt/netdata]# stop_all_netdata
OK ''
Starting netdata using command 'systemctl start netdata'
[/opt/netdata]# systemctl start netdata
OK ''
Ooops! it seems netdata is not started.
Attempting another netdata start using command 'systemctl start netdata'
OK ''
Hm... it seems netdata is still not started.
WARNING Netdata service still not started, attempting another forced restart by running '/opt/netdata/bin/netdata '
OK ''
[/opt/netdata]# /opt/netdata/bin/netdata
time=2024-03-03T17:19:43.364+01:00 comm=netdata source=daemon level=info errno="2, No such file or directory" tid=1430 thread=netdata msg="CONFIG: cannot load user config '/opt/netdata/etc/netdata/netdata.conf'. Will try the stock version."
time=2024-03-03T17:19:43.366+01:00 comm=netdata source=daemon level=info errno="2, No such file or directory" tid=1430 thread=netdata msg="CONFIG: cannot load stock config '/opt/netdata/usr/lib/netdata/conf.d/netdata.conf'. Running with internal defaults."
time=2024-03-03T17:19:43.368+01:00 comm=netdata source=daemon level=info errno="2, No such file or directory" tid=1430 thread=netdata msg="CONFIG: cannot load cloud config '/opt/netdata/var/lib/netdata/cloud.d/cloud.conf'. Running with internal defaults."
system/functions.sh: line 458: 1430 Illegal instruction "${@}"
FAILED ''
|.-. .-. .-. .-. .-. . netdata .-. .-. .-. .-. .-. .-
[/opt/netdata]# chmod 0644 /opt/netdata/etc/netdata/netdata.conf
OK ''
OK
Root privileges required to run sh -c cat "/opt/netdata/etc/netdata/.install-type" > "/tmp/netdata-kickstart-U2S5RwH98G/install-type"
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo sh -c cat "/opt/netdata/etc/netdata/.install-type" > "/tmp/netdata-kickstart-U2S5RwH98G/install-type"
OK
Root privileges required to run chown 1000:1000 /tmp/netdata-kickstart-U2S5RwH98G/install-type
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo chown 1000:1000 /tmp/netdata-kickstart-U2S5RwH98G/install-type
OK
Root privileges required to run chown netdata:netdata /tmp/netdata-kickstart-U2S5RwH98G/install-type
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo chown netdata:netdata /tmp/netdata-kickstart-U2S5RwH98G/install-type
OK
Root privileges required to run cp /tmp/netdata-kickstart-U2S5RwH98G/install-type /opt/netdata/etc/netdata/.install-type
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo cp /tmp/netdata-kickstart-U2S5RwH98G/install-type /opt/netdata/etc/netdata/.install-type
OK
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo test -x /opt/netdata/usr/libexec/netdata/netdata-updater.sh
OK
Root privileges required to run grep -q \-\-enable-auto-updates /opt/netdata/usr/libexec/netdata/netdata-updater.sh
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo grep -q \-\-enable-auto-updates /opt/netdata/usr/libexec/netdata/netdata-updater.sh
OK
Root privileges required to run /opt/netdata/usr/libexec/netdata/netdata-updater.sh --enable-auto-updates
[/tmp/netdata-kickstart-U2S5RwH98G]$ sudo /opt/netdata/usr/libexec/netdata/netdata-updater.sh --enable-auto-updates
Sun 3 Mar 17:19:44 CET 2024 : INFO: netdata-updater.sh: Auto-updating has been ENABLED through cron, updater script linked to /etc/cron.daily/netdata-updater
Sun 3 Mar 17:19:44 CET 2024 : INFO: netdata-updater.sh: If the update process fails and you have email notifications set up correctly for cron on this system, you should receive an email notification of the failure.
Sun 3 Mar 17:19:44 CET 2024 : INFO: netdata-updater.sh: Successful updates will not send an email.
OK
Successfully installed the Netdata Agent.
- Unable to determine Linux distribution for native packages.
- Could not install native binary packages, falling back to alternative installation method.
Root privileges required to run rm -rf /tmp/netdata-kickstart-U2S5RwH98G
[/home/usr]$ sudo rm -rf /tmp/netdata-kickstart-U2S5RwH98G
OK
