ioping_disk_latency
OS: Any
This alert presents the average I/O latency over the last 10 seconds.
I/O latencyis the time that is required to complete a single I/O operation on a block device.
If this alert is raised, it might indicate that your disk is under high load, or that the disk is slow.
Troubleshooting Section
Check related charts to find your case
First, you need to identify whether your disk is under high load or not.
- Go to your node on the Netdata Cloud, on the
Diskssection, and select the disk you want to
investigate.
- On the top of the page you can see the utilization of the disk, and you can also go to the
Disk I/O Bandwidthchart. There you can see the amount of transferred datatoandfromthe particular disk.
If the utilization is low and there isn’t a significant amount of data being transferred, your
drive’s latency is slow, so you need to upgrade that drive. (If it is an HDD, then an SSD would be a significant upgrade for latency issues.) -
If there is a high load on the drive, it usually means that one or more processes are heavily utilizing the drive.
