Summary:
I have created my ext4 file systems without reserved space for root (reserved block count) during the Debian12 installation using the -m 0 option with mkfs.ext4. This configuration is correctly applied to all partitions, and I am able to see the 0% reserved space for all my partitions
Partition List:
root@DEB-ZBOXMI35-GXXXX472XXXXX:~# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 232.9G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /boot/efi
├─nvme0n1p2 259:2 0 18G 0 part /
├─nvme0n1p3 259:3 0 6G 0 part /opt/debian12/log
└─nvme0n1p4 259:4 0 208.4G 0 part /var/lib/docker
Verification of Reserved Block Count:
All partitions show a reserved block count of 0:
root@DEB-ZBOXMI35-GXXXX472XXXXX:~# sudo dumpe2fs -h /dev/nvme0n1p2 | grep -i "reserved block count"
dumpe2fs 1.47.0 (5-Feb-2023)
Reserved block count: 0
root@DEB-ZBOXMI35-GXXXX472XXXXX:~# sudo dumpe2fs -h /dev/nvme0n1p3 | grep -i "reserved block count"
root@DEB-ZBOXMI35-GXXXX472XXXXX:~# sudo dumpe2fs -h /dev/nvme0n1p4 | grep -i "reserved block count"
Netdata Configuration:
Here is my current Netdata configuration for disk space:
[plugin:proc:diskspace]
update every = 60
exclude space metrics on paths = /proc/* /sys/* /var/run/user/* /run/user/* /var/lib/docker/* /dev /dev/shm /run /run/*
inodes usage for all disks = no
[plugin:proc:/proc/diskstats]
exclude disks = loop* ram* boot rootfs rex-kmshare ext4
merged operations for all disks = no
backlog for all disks = no
i/o time for all disks = no
enable new disks detected at runtime = no
[plugin:proc:/proc/diskstats:sda]
enable = yes
enable performance metrics = auto
bandwidth = auto
operations = auto
merged operations = no
queued operations = auto
utilization percentage = auto
extended operations = no
[plugin:proc:/proc/diskstats:nvme0n1]
enable = yes
bandwidth = auto
operations = auto
In Netdata, the reserved space for root is correctly shown as 0% for 2 partitions ( /root & /var/lib/docker) out of 3 partitions.
Issue:
But the reserved space for root is incorrectly displays as 0.2 for one partition ( /opt/debian12/log) but the Internally its value is set to 0 only.
- Manual Calculation of Reserved Space:
Manually calculated reserved space to cross-verify the displayed value:
Confirmed that the reserved block count is indeed 0.
Request for Assistance:
I am aware that we can hide this dimension from Netdata charts, but I don’t want to hide it. I want to understand the underlying mechanism and why it is showing 0.2% for this partition despite the actual reserved space being set to 0%.
Any guidance on resolving this discrepancy would be greatly appreciated.
Thank you in advance for your help!
