I have latest Netdata installed at a LXC container and get now apperently stats from the host instead of the LXC container.
The LXC Container (named ansible) is hosted at a Proxmox installation and the ceph is used as container storage.
It looks like it mixes hosts stats and container stats, I am just installed it with no further configuration, so I am unsure if this is some behavior I could adjust or is not supported ?
root@ansible:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/rbd13 15G 3.0G 11G 22% /
none 492K 4.0K 488K 1% /dev
tmpfs 32G 184K 32G 1% /dev/shm
tmpfs 13G 148K 13G 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 6.3G 0 6.3G 0% /run/user/0
Here it reports some data I have no idea from where it comes from.
The 54,76GiB the total 10.24TiB are unreasonable and can’t get find at the host either (or some combination from some values that are unknown to me)
On the other hand the 3GiB free storage is correct.
At the memory tab it looks okay besides the total committed memory that is completely off the charts and likewise a value from the barebone host.
