After installing the netdata agent in the LXC container, the software does not collect statistics from the system in LXC but collects statistics from the entire bare-meta server. The software installed on the server is Proxmox 7.2-7, Ubuntu 20.04 is installed in the LXC container. The problem is very similar to this description..
Configuration files are default, no changes have been made. I would like your help as I want to monitor my LXC containers.
http://192.168.100.132:19999/api/v1/info
"version": "v1.35.1",
"uid": "bd2732cc-125c-11ed-90d6-bb82168db5e1",
"mirrored_hosts": [
"netdata-test"
"mirrored_hosts_status": [
{ "guid": "bd2732cc-125c-11ed-90d6-bb82168db5e1", "hostname": "netdata-test", "reachable": true, "hops": 0, "claim_id": null, "node_id": null }
"alarms": {
"normal": 78,
"warning": 0,
"critical": 0
"os_name": "Ubuntu",
"os_id": "ubuntu",
"os_id_like": "debian",
"os_version": "20.04.4 LTS (Focal Fossa)",
"os_version_id": "20.04",
"os_detection": "/etc/os-release",
"cores_total": "16",
"total_disk_space": "3925996470272",
"cpu_freq": "2394000000",
"ram_total": "1073741824",
"container_os_name": "none",
"container_os_id": "none",
"container_os_id_like": "none",
"container_os_version": "none",
"container_os_version_id": "none",
"container_os_detection": "none",
"is_k8s_node": "false",
"kernel_name": "Linux",
"kernel_version": "5.15.39-2-pve",
"architecture": "x86_64",
"virtualization": "none",
"virt_detection": "systemd-detect-virt",
"container": "unknown",
"container_detection": "systemd-detect-virt",
"cloud_provider_type": "unknown",
"cloud_instance_type": "unknown",
"cloud_instance_region": "unknown",
"host_labels": {
"_is_parent": "false",
"_aclk_ng_new_cloud_protocol": "true",
"_aclk_proxy": "none",
"_aclk_impl": "Next Generation",
"_mqtt_version": "3",
"_aclk_legacy_available": "false",
"_aclk_ng_available": "true",
"_prebuilt_dist": " ",
"_prebuilt_arch": "x86_64",
"_install_type": "binpkg-deb",
"_is_k8s_node": "false",
"_virt_detection": "systemd-detect-virt",
"_container_detection": "systemd-detect-virt",
"_container": "unknown",
"_virtualization": "none",
"_architecture": "x86_64",
"_system_disk_space": "3925996470272",
"_system_ram_total": "1073741824",
"_system_cpu_freq": "2394000000",
"_system_cores": "16",
"_kernel_version": "5.15.39-2-pve",
"_os_version": "20.04.4 LTS (Focal Fossa)",
"_os_name": "Ubuntu",
"_cloud_instance_region": "unknown",
"_cloud_instance_type": "unknown",
"_cloud_provider_type": "unknown"
"collectors": [
"plugin": "proc.plugin",
"module": "/proc/net/snmp"
"module": "/proc/diskstats"
"plugin": "cgroups.plugin",
"module": "systemd"
"plugin": "netdata",
"module": "stats"
"plugin": "python.d.plugin",
"module": "postfix"
"plugin": "timex.plugin",
"module": ""
"module": "sensors"
"module": "ipc"
"module": "/proc/spl/kstat/zfs"
"module": "/proc/spl/kstat/zfs/arcstats"
"module": "/proc/net/stat/nf_conntrack"
"module": "/proc/net/softnet_stat"
"module": "/proc/net/snmp6"
"module": "/proc/net/netstat"
"module": "/proc/net/sockstat6"
"module": "/proc/net/sockstat"
"module": "/sys/devices/system/node"
"module": "/sys/kernel/mm/ksm"
"plugin": "apps.plugin",
"module": ""
"module": "/proc/meminfo"
"module": "/proc/vmstat"
"module": "/proc/softirqs"
"module": "/proc/interrupts"
"module": "/proc/pressure"
"module": "/proc/sys/kernel/random/entropy_avail"
"module": "/proc/loadavg"
"module": "/proc/uptime"
"module": "/proc/stat"
"module": "/proc/net/dev"
"plugin": "diskspace.plugin",
"module": ""
"plugin": "nfacct.plugin",
"module": ""
"plugin": "tc.plugin",
"module": ""
"plugin": "statsd.plugin",
"module": "stats"
"plugin": "idlejitter.plugin",
"module": ""
"cloud-enabled": true,
"cloud-available": true,
"aclk-ng-available": true,
"aclk-ng-new-cloud-protocol": true,
"aclk-legacy-available": false,
"aclk-implementation": "Next Generation",
"agent-claimed": false,
"aclk-available": false,
"aclk-available-protocol": null,
"memory-mode": "dbengine",
"multidb-disk-quota": 256,
"page-cache-size": 32,
"stream-enabled": false,
"stream-compression": true,
"hosts-available": null,
"https-enabled": true,
"buildinfo": "dbengine|Native HTTPS|Netdata Cloud|ACLK Next Generation|New Cloud Protocol Support|TLS Host Verification|Machine Learning|Stream Compression|protobuf|JSON-C|libcrypto|libm|zlib|apps|cgroup Network Tracking|CUPS|EBPF|IPMI|NFACCT|perf|slabinfo|Prometheus Remote Write",
"release-channel": "stable",
"web-enabled": true,
"notification-methods": null,
"exporting-enabled": null,
"exporting-connectors": null,
"allmetrics-prometheus-used": null,
"allmetrics-shell-used": null,
"allmetrics-json-used": null,
"dashboard-used": 1,
"charts-count": null,
"metrics-count": null,
"ml-info": {
"enabled": false
