On a fresh Ubuntu 22.04 LTS install the applications, users, etc graphs are missing. I have another Ubuntu 22.04 system using the same version including kernel and this does not have this issue.
I noticed the service has an error message for ebpf plugin which the other system does not have.
# service netdata status
Active: active (running) since Tue 2022-06-14 05:16:14 EDT; 16min ago
Main PID: 11824 (netdata)
Tasks: 82 (limit: 154433)
Memory: 90.6M
CPU: 16.015s
├─11824 /usr/sbin/netdata -D -P /var/run/netdata/netdata.pid
├─11826 /usr/sbin/netdata --special-spawn-server
├─11969 bash /usr/libexec/netdata/plugins.d/tc-qos-helper.sh 1
├─11984 /usr/bin/python3 /usr/libexec/netdata/plugins.d/python.d.plugin 1
├─11988 /usr/libexec/netdata/plugins.d/freeipmi.plugin 1
├─11990 /usr/libexec/netdata/plugins.d/go.d.plugin 1
└─11992 /usr/libexec/netdata/plugins.d/nfacct.plugin 1
Jun 14 05:16:14 ubuntu systemd[1]: Started Real time performance monitoring.
Jun 14 05:16:15 ubuntu ebpf.plugin[11987]: Your environment does not have BTF file /sys/kernel/btf//vmlinux. The plugin will work with 'legacy' code.
Jun 14 05:16:15 ubuntu ebpf.plugin[11987]: Name resolution is disabled, collector will not parser "hostnames" list.
Jun 14 05:16:15 ubuntu ebpf.plugin[11987]: The network value of CIDR 127.0.0.1/8 was updated for 127.0.0.0 .
Jun 14 05:16:15 ubuntu ebpf.plugin[11987]: Loaded config file '/etc/netdata/apps_groups.conf'
Jun 14 05:16:15 ubuntu ebpf.plugin[11987]: PROCFILE: Cannot open file '/proc/10644/status'
Jun 14 05:16:15 ubuntu ebpf.plugin[11987]: Cannot open /proc/10644/status
Active: active (running) since Sat 2022-06-11 06:46:11 EDT; 2 days ago
Main PID: 1584942 (netdata)
Tasks: 78 (limit: 77019)
Memory: 361.2M
CPU: 3h 4min 28.573s
├─1584942 /usr/sbin/netdata -D -P /var/run/netdata/netdata.pid
├─1585247 /usr/sbin/netdata --special-spawn-server
├─1585421 /usr/libexec/netdata/plugins.d/go.d.plugin 1
├─1585425 /usr/bin/python3 /usr/libexec/netdata/plugins.d/python.d.plugin 1
├─1585427 /usr/libexec/netdata/plugins.d/apps.plugin 1
├─2639726 /usr/libexec/netdata/plugins.d/nfacct.plugin 1
├─2640849 bash /usr/libexec/netdata/plugins.d/charts.d.plugin 1
├─2747924 /usr/libexec/netdata/plugins.d/freeipmi.plugin 1
└─3293190 bash /usr/libexec/netdata/plugins.d/tc-qos-helper.sh 1
Jun 11 10:49:12 ubuntu ebpf.plugin[2890002]: Does not have a configuration file inside `/etc/netdata/ebpf.d.conf. It will try to load stock file.
Jun 11 10:49:12 ubuntu ebpf.plugin[2890002]: Your environment does not have BTF file /sys/kernel/btf//vmlinux. The plugin will work with 'legacy' code.
Jun 11 10:49:12 ubuntu ebpf.plugin[2890002]: Name resolution is disabled, collector will not parser "hostnames" list.
Jun 11 10:49:12 ubuntu ebpf.plugin[2890002]: The network value of CIDR 127.0.0.1/8 was updated for 127.0.0.0 .
Jun 11 10:49:12 ubuntu ebpf.plugin[2890002]: Cannot read process groups configuration file '/etc/netdata/apps_groups.conf'. Will try '/usr/lib/netdata/conf.d/>
Jun 11 10:49:23 ubuntu ebpf.plugin[2890756]: Does not have a configuration file inside `/etc/netdata/ebpf.d.conf. It will try to load stock file.
Jun 11 10:49:23 ubuntu ebpf.plugin[2890756]: Your environment does not have BTF file /sys/kernel/btf//vmlinux. The plugin will work with 'legacy' code.
Jun 11 10:49:23 ubuntu ebpf.plugin[2890756]: Name resolution is disabled, collector will not parser "hostnames" list.
Jun 11 10:49:23 ubuntu ebpf.plugin[2890756]: The network value of CIDR 127.0.0.1/8 was updated for 127.0.0.0 .
Jun 11 10:49:23 ubuntu ebpf.plugin[2890756]: Cannot read process groups configuration file '/etc/netdata/apps_groups.conf'. Will try '/usr/lib/netdata/conf.d/
Ubuntu 22.04 LTS with XanMod 5.18
# netdata -W buildinfo
Version: netdata v1.35.0-13-nightly
Configure options: '--build=x86_64-linux-gnu' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--disable-option-checking' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--libexecdir=${prefix}/lib/x86_64-linux-gnu' '--disable-maintainer-mode' '--prefix=/usr' '--sysconfdir=/etc' '--localstatedir=/var' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--with-user=netdata' '--with-math' '--with-zlib' '--with-webdir=/var/lib/netdata/www' '--disable-dependency-tracking' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -ffile-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -ffile-prefix-map=/usr/src/netdata=. -fstack-protector-strong -Wformat -Werror=format-security'
Install type: binpkg-deb
Binary architecture: x86_64
Packaging distro:
Features:
dbengine: YES
Native HTTPS: YES
Netdata Cloud: YES
ACLK Next Generation: YES
ACLK Legacy: NO
TLS Host Verification: YES
Machine Learning: YES
Stream Compression: YES
Libraries:
protobuf: YES (system)
jemalloc: NO
JSON-C: YES
libcap: NO
libcrypto: YES
libm: YES
tcalloc: NO
zlib: YES
Plugins:
apps: YES
cgroup Network Tracking: YES
CUPS: YES
EBPF: YES
IPMI: YES
NFACCT: YES
perf: YES
slabinfo: YES
Xen: NO
Xen VBD Error Tracking: NO
Exporters:
AWS Kinesis: NO
GCP PubSub: NO
MongoDB: NO
Prometheus Remote Write: YES
Graphs to load for Applications.
