Daily Ubuntu 20.04LTS reports _usr_libexec_netdata_plugins.d_ebpf.plugin.0.crash
Daily after the nightly Netdata update I get ‘Ubuntu has experienced a problem’. Each day there is an entry in /var/crash - _usr_libexec_netdata_plugins.d_ebpf.plugin.0.crash I’ve put the information from that file on pastebin - https://pastebin.com/6t1Pnhds The plugin appears to be running however so the crash report may not be correct.
This is Ubuntu 20.04LTS, Netdata was installed via the kickstart.sh script
Hello @chris.pollock,
What is the kernel version that you are running on this Ubuntu?
Best regards!
@Thiago_Marques_0 Kernel 5.4.0-58-generic, note I didn’t see this today after the nightly update so possibly something fixed it in the update.
Hello @chris.pollock we did not merge anything new for ebpf.plugin , I will try to replicate the error, but I already made a fix for problems that were happening on Ubuntu 18.04 (Fix for old kernel by thiagoftsm · Pull Request #183 · netdata/kernel-collector · GitHub).
I will give more details when I finish the tests.
Best regards!
@chris.pollock I tried to recreate the problem, but like you I could not have it yesterday and today, if it repeats, please, let us know.
