Suggested template:
The majority of metrics under k8s kubelet are reporting zeros.
netdata/netdata:v1.33.1
For one example, I would expect to see 6 for Number Of Pods Currently Running (k8s_kubelet.kubelet_pods_running) on the node I’m looking at in netdata cloud (or looking at the node directly via $KUBENODE:19999/).
If I open a shell in the netdata child pod on that node and execute curl http://127.0.0.1:10255/metrics | grep kubelet_running_pods I get kubelet_running_pods 6. But all charts report 0.
I do see non-zero values in netdata.cloud (and on host directly) for Bytes Used By The Pod Logs On The Filesystem (k8s_kubelet.kubelet_pods_log_filesystem_used_bytes).
This is all running on a Microk8s v1.22.6 cluster and netdata was deployed via helm (via fluxcd).
Kubelet config:
kubelet:
data: |
update_every: 1
jobs:
- url: http://127.0.0.1:10255/metrics
timeout: 5
- url: https://localhost:10250/metrics
tls_skip_verify: yes
timeout: 5
