Mixed plain and SSLed data streaming issue
I have a Netdata (v1.39.1) parent host collecting data from ~300 hosts (mostly v1.37.1).
Currently data collection works well but via HTTP.
Due to current security trends I would like to move to SSL.
As it is not that easy to reconfigure all 300 hosts in one moment I would like to apply “^SSL=optional”
to have both HTTP and HTTPS streaming. As soon as all hosts are SSLed I switch to “^SSL=force”.
Here is HTTP config. All works well here.
[web]
    default port = 19999
    bind to = *:http=dashboard|management|netdata.conf netdata.mydomain.com:19999=streaming|registry
    web files owner = root
    web files group = netdata
    enable web responses gzip compression = no
#    ssl key = /etc/netdata/ssl/mydomain.com.key
#    ssl certificate = /etc/netdata/ssl/mydomain.com.crt
and here is new one. The only change is “^SSL=optional” and certs added.
[web]
    bind to = *:http=dashboard|management|netdata.conf netdata.mydomain.com:19999=streaming|registry^SSL=optional
As soon as I activate new config all streams to parent host stop working.
Here is what child (UTC time zone) says about parent:
2023-05-30 09:29:25: netdata ERROR : STREAM_SENDER[systemAAc01.mydomain.com] : Clearing stream_collected_metrics flag in charts of host systemAAc01.mydomain.com
2023-05-30 09:29:25: netdata INFO  : STREAM_SENDER[systemAAc01.mydomain.com] : STREAM systemAAc01.mydomain.com: attempting to connect to 'netdata.mydomain.com' (default port: 19999)...
2023-05-30 09:29:25: netdata INFO  : STREAM_SENDER[systemAAc01.mydomain.com] : STREAM systemAAc01.mydomain.com [send to netdata.mydomain.com]: initializing communication...
2023-05-30 09:29:25: netdata INFO  : STREAM_SENDER[systemAAc01.mydomain.com] : STREAM systemAAc01.mydomain.com [send to netdata.mydomain.com]: waiting response from remote netdata...
2023-05-30 09:29:26: netdata ERROR : STREAM_SENDER[systemAAc01.mydomain.com] : Clearing stream_collected_metrics flag in charts of host systemAAc01.mydomain.com
2023-05-30 09:29:26: netdata ERROR : STREAM_SENDER[systemAAc01.mydomain.com] : STREAM systemAAc01.mydomain.com [send to netdata.mydomain.com]: remote netdata does not respond.
2023-05-30 09:29:31: netdata ERROR : STREAM_SENDER[systemAAc01.mydomain.com] : Clearing stream_collected_metrics flag in charts of host systemAAc01.mydomain.com
2023-05-30 09:29:31: netdata INFO  : STREAM_SENDER[systemAAc01.mydomain.com] : STREAM systemAAc01.mydomain.com: skipping destination 'netdata.mydomain.com' (default port: 19999) due to last error (code: -6, timeout while expecting first response), will retry it in 25 seconds
And here is parent log (CET time zone):
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : thread created with task id 83125
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : set name of thread 83125 to RCVR[systemAA
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : STREAM systemAAc01.mydomain.com [11.11.11.20]:43476: receive thread created (task id 83125)
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : Host systemAAc01.mydomain.com is not in archived mode anymore
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : STREAM systemAAc01.mydomain.com [receive from [11.11.11.20]:43476]: established link with negotiated capabilities: VCAPS HLABELS CLAIM CLABELS FUNCTIONS REPLICATION BINARY
2023-05-30 11:29:26: netdata ERROR : RCVR[systemAA : cannot write to SSL connection - connection is not ready.
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : STREAM 'systemAAc01.mydomain.com' [receive from [11.11.11.20]:43476]: cannot reply back. STATUS: CANT REPLY DROPPING CONNECTION
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : STREAM 'systemAAc01.mydomain.com' [receive from [11.11.11.20]:43476]: receive thread ended (task id 83125)
2023-05-30 11:29:26: netdata INFO  : RCVR[systemAA : thread with task id 83125 finished
As you can see child and parent negotiated capabilities, thus I assume HTTP connection setup was completed successfully.
But suddenly parent decides to talk back SSL to client: “cannot write to SSL connection - connection is not ready”.
At this stage all falling apart and no streaming works.
Any hints what can be wrong with SSL configuration here?
Parent streaming configuration:
$ cat /etc/netdata/stream.conf
[f1020749-6916-40fe-a425-ee2fc5fcaaf5]
    enabled = yes
    allow from = *
    default postpone alarms on connect seconds = 300
    enable compression = yes
$ netdata -W buildinfo
Version: netdata v1.39.1
Configure options:  '--prefix=/usr' '--sbindir=/usr/bin' '--sysconfdir=/etc' '--libexecdir=/usr/lib' '--localstatedir=/var' '--with-zlib' '--with-math' '--with-user=netdata' 'CFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions         -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security         -fstack-clash-protection -fcf-protection -g -ffile-prefix-map=/build/netdata/src=/usr/src/debug/netdata -flto=auto' 'LDFLAGS=-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now -flto=auto' 'CXXFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions         -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security         -fstack-clash-protection -fcf-protection -Wp,-D_GLIBCXX_ASSERTIONS -g -ffile-prefix-map=/build/netdata/src=/usr/src/debug/netdata -flto=auto'
Install type: custom
Features:
Libraries:
    jemalloc:                NO
    JSON-C:                  YES
    libcap:                  YES
    libcrypto:               YES
    libm:                    YES
    tcalloc:                 NO
    zlib:                    YES
Plugins:
    apps:                    YES
    cgroup Network Tracking: YES
    CUPS:                    YES
    EBPF:                    NO
    IPMI:                    NO
    NFACCT:                  YES
    perf:                    YES
    slabinfo:                YES
    Xen:                     NO
    Xen VBD Error Tracking:  NO
Exporters:
    AWS Kinesis:             NO
    GCP PubSub:              NO
    MongoDB:                 YES
    Prometheus Remote Write: YES
Debug/Developer Features:
    Trace Allocations:       NO
$ openssl version
OpenSSL 3.0.8 7 Feb 2023 (Library: OpenSSL 3.0.8 7 Feb 2023)
$ ldd /usr/bin/netdata | grep ssl
        libssl.so.3 => /usr/lib/libssl.so.3 (0x00007f3b53d38000)
Child configuration:
$ cat /etc/netdata/netdata.conf
        memory mode = none
        update every = 4
[web]
        mode = none
[registry]
        enabled = no
        registry to announce = http://netdata.mydomain.com:19999
[statsd]
        enabled = no
[stream]
    enabled = yes
    destination = netdata.mydomain.com
    api key = f1020749-6916-40fe-a425-ee2fc5fcaaf5
# netdata -W buildinfo
Version: netdata v1.37.1
Configure options:  '--build=x86_64-redhat-linux-gnu' '--host=x86_64-redhat-linux-gnu' '--program-prefix=' '--disable-dependency-tracking' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib64' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/var/lib' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--enable-plugin-freeipmi' '--with-bundled-protobuf' '--with-zlib' '--with-math' '--with-user=netdata' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1  -m64 -mtune=generic' 'LDFLAGS=-Wl,-z,relro -specs=/usr/lib/rpm/redhat/redhat-hardened-ld' 'CXXFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1  -m64 -mtune=generic' 'PKG_CONFIG_PATH=:/usr/lib64/pkgconfig:/usr/share/pkgconfig'
Features:
    Stream Compression:         NO
Libraries:
    protobuf:                YES (bundled)
    jemalloc:                NO
    JSON-C:                  YES
    libcap:                  YES
    libcrypto:               YES
    libm:                    YES
    tcalloc:                 NO
    zlib:                    YES
Plugins:
    apps:                    YES
    CUPS:                    NO
    EBPF:                    NO
    IPMI:                    YES
    NFACCT:                  NO
    perf:                    YES
    slabinfo:                YES
    Xen:                     NO
Exporters:
    AWS Kinesis:             NO
    GCP PubSub:              NO
    MongoDB:                 NO
$ openssl version
OpenSSL 1.0.2k-fips  26 Jan 2017
$ ldd /sbin/netdata | grep ssl
        libssl.so.10 => /lib64/libssl.so.10 (0x00007faa5d656000)
Hi @lex sorry for the late reply. Just to note that we are looking into it and will come back with more info. Thank you!
Parent update to netdata v1.40.0 greatly improved situation.
Streaming with SSL=optional works well with SSLed and plain children.
No update on children was needed, still have most on 1.37.1.
