SSL stream between docker node
Hi, I have a problem to make ssl stream between two agents in docker containers. When I disable ssl on child node everything works without any problem. I have a self-signed certificate in the “ssl” folder with privileges netdata:netdata bound to /etc/netdata/ssl. What could I have wrong? Thank you for any ideas.
Parent node
netdata.conf
[web]
bind to = *:19999=dashboard|netdata.conf^SSL=optional *:19996=streaming|management^SSL=optional
stream.conf
[my api key]
    enabled = yes
child
stream.conf
[stream]
    enabled = yes
    destination = my_ip:19996:SSL
    ssl skip certificate verification = yes
    api key = my_api_key
Hi @Michal_Dvorak - apologies for the delay.
Do you see any errors in the child or parent logs?
@Michal_Dvorak also, could you please share the netdata version you’re using? Thanks!
Hi, thank you so much for the help, the problem was, on the parent server was night version and on the
server child was stable version of container.
