Thanks for sharing that @rodrigo2. Being the version the same the only thing that comes to my mind then is checking that the plugin is enabled on the RPi-1 - not sure why it would have been disabled all of sudden
# netdata python.d.plugin configuration for sensors
# This file is in YaML format. Generally the format is:
# name: value
# Global Variables
# These variables set the defaults for all JOBs, however each JOB
# may define its own, overriding the defaults.
# update_every sets the default data collection frequency.
# If unset, the python.d.plugin default is used.
# update_every: 1
# priority controls the order of charts at the netdata dashboard.
# Lower numbers move the charts towards the top of the page.
# If unset, the default for python.d.plugin is used.
# priority: 60000
# penalty indicates whether to apply penalty to update_every in case of failures.
# Penalty will increase every 5 failed updates in a row. Maximum penalty is 10 minutes.
# penalty: yes
# autodetection_retry sets the job re-check interval in seconds.
# The job is not deleted if check fails.
# Attempts to start the job are made once every autodetection_retry.
# This feature is disabled by default.
# autodetection_retry: 0
# Limit the number of sensors types.
# Comment the ones you want to disable.
# Also, re-arranging this list controls the order of the charts at the
# netdata dashboard.
types:
- temperature
- fan
- voltage
- current
- power
- energy
- humidity
# Limit the number of sensors chips.
# Uncomment the first line (chips:) and add chip names below it.
# The chip names that start with like that will be matched.
# You can find the chip names using the sensors command.
#chips:
# - i8k
# - coretemp
# chip names can be found using the sensors shell command
# the prefix is matched (anything that starts like that)
Output of ./edit-config go.d.conf:
# netdata go.d.plugin configuration
# This file is in YAML format.
# Enable/disable the whole go.d.plugin.
enabled: yes
# Enable/disable default value for all modules.
default_run: yes
# Maximum number of used CPUs. Zero means no limit.
max_procs: 0
# Enable/disable specific g.d.plugin module
# If you want to change any value, you need to uncomment out it first.
# IMPORTANT: Do not remove all spaces, just remove # symbol. There should be a space before module name.
modules:
# activemq: yes
# apache: yes
# bind: yes
# chrony: yes
# cockroachdb: yes
# consul: yes
# coredns: yes
# couchbase: yes
# couchdb: yes
# dnsdist: yes
# dnsmasq: yes
# dnsmasq_dhcp: yes
# dns_query: yes
# docker: yes
# docker_engine: yes
# dockerhub: yes
# elasticsearch: yes
# envoy: yes
# example: no
# filecheck: yes
# fluentd: yes
# freeradius: yes
# haproxy: yes
# hdfs: yes
# httpcheck: yes
# isc_dhcpd: yes
# k8s_kubelet: yes
# k8s_kubeproxy: yes
# lighttpd: yes
# logind: yes
# logstash: yes
# mongodb: yes
# mysql: yes
# nginx: yes
# nginxplus: yes
# nginxvts: yes
# ntpd: yes
# nvme: yes
# nvidia_smi: no
# openvpn: no
# openvpn_status_log: yes
# ping: yes
# pgbouncer: yes
# phpdaemon: yes
# phpfpm: yes
# pihole: yes
# pika: yes
# portcheck: yes
# postgres: yes
# powerdns: yes
# powerdns_recursor: yes
# prometheus: yes
# pulsar: yes
# rabbitmq: yes
# redis: yes
# scaleio: yes
# snmp: yes
# solr: yes
# springboot2: yes
# squidlog: yes
# supervisord: yes
# systemdunits: yes
# tengine: yes
# traefik: yes
# unbound: yes
# vernemq: yes
# vcsa: yes
# vsphere: yes
# web_log: yes
# wireguard: yes
# whoisquery: yes
# windows: yes
# x509check: yes
# zookeeper: yes
No mention for sensors or temperatures.
And on RPi-2 (for which Netdata does show a temperature) - no “sensors” entry as well.
Tried to add manually:
Must admit that editing by edit-config is absolutely not intuitive & friendly.
Have no idea how to save changes.
Only managed to leave the editor by pressing Ctrl-Z.
Managed to save changes (using vi), restarted Netdata then (docker restart netdata).
And still no “Sensors” section in web interface.
Ran ./edit-config go.d.conf, the added sensors: yes is there, but no positive effect.
I believe we will need to move this into a bug report, could you please open one here and add as many details as you can? (probably even looking to error logs).
